Client Details
The page displays the number of clients connected to the wireless and wired networks. By default, the page displays a unified list of clients for the selected group.
The client details page shows a summary of the client and allows you to navigate to the corresponding device details page.
The wired client shows up in the page only if the client is connected to an Aruba 2540 Series, Aruba 2920 Series, Aruba 2930F Series, Aruba 2930M Series, Aruba 3810 Series, or Aruba 5400R Series switch. |
This section includes the following topics:
Viewing Clients Connected to Wireless Networks
Disconnecting a Wireless Client from an AP
Blacklisting a Wireless Client from an AP
Viewing Clients Connected to Wired Networks
To view the details of a client connected to the wireless network:
1. In the app, use the filter bar to select a group or a device.
2. Under , click . The clients overview page is displayed.
3. Click the list icon to view the client table.
4. By default, the table displays a unified list of clients for the selected group.
5. Click the client name to view the client details page. If there are many clients connected to the network, click to filter the clients connected to the wireless network and enter the client name in the column and then click the client name. The page is displayed.
Client Summary Bar
The client summary bar displays the following information:
Field |
Description |
MACMedia Access Control. A MAC address is a unique identifier assigned to network interfaces for communications on a network. address and connection status |
MAC address of the device to which the client is connected and connection status. Connection status is updated immediately on state change. |
Signal strength of the client device. The signal strength value is displayed in percentage: 0-25—Poor 26-50—Fair 50-100—Good |
SNRSignal-to-Noise Ratio. SNR is used for comparing the level of a desired signal with the level of background noise. for the client as measured by the AP. The SNR value is displayed in decibels: 0-20—Poor 21-35—Fair >35—Good |
Data transmission rate. |
Data reception rate. |
Name of the AP that broadcasts the SSIDService Set Identifier. SSID is a name given to a WLAN and is used by the client to access a WLAN network. to which the client is connected. Click the name of the AP to view the device details page. |
To disconnect a wireless client from an online AP:
5. Click the name of the wireless client to open the corresponding page. If there are many clients connected to the network, click to filter the clients connected to the wireless network, enter the client name in the column, and click the client name.
6. From the drop-down list, click .
The drop-down is disabled if the AP is offline. To disconnect a wireless client, ensure that there is an established Websocket connection from the controller to Aruba Central. |
To blacklist a wireless client from an online AP:
3. Click the list icon to view the clients table.
The wireless client details page displays the client details summary and the client sessions information.
Wireless Client Summary
The wireless client summary page consists the following tabs:
Overview
The page displays information about the type of data path that the client uses, the network and connectivity details, and basic client details such as IP address of the client, type of encryption etc. The following table describes the information displayed in each section:
Section |
Description |
Displays the data path of the client in the network. Click the AP icon to view the AP details page. The data path can be one of the following: > > > > > > > > > > > > |
Displays the following information: —User name of the client. —Hostname of the client. —Type of the client device. —IP address of the client. —Manufacturer of the client device. —Type of client encryption. —Date and time since when the client is connected. —Operating system running on the client device. |
Displays the following information: —Displays the VLANVirtual Local Area Network. In computer networking, a single Layer 2 network may be partitioned to create multiple distinct broadcast domains, which are mutually isolated so that packets can only pass between them through one or more routers; such a domain is referred to as a Virtual Local Area Network, Virtual LAN, or VLAN. ID on which the client is connected to the AP. —Displays the VLAN derivation method used for assigning an IP address to the client. Aruba devices can assign a static or dynamically derived IP address from a DHCPDynamic Host Configuration Protocol. A network protocol that enables a server to automatically assign an IP address to an IP-enabled device from a defined range of numbers configured for a given network. pool to the clients. —Displays the role assigned to the client by the AP. |
Displays the following information: —Radio channel assigned to the client. —Radio bandBand refers to a specified range of frequencies of electromagnetic radiation. on which the client is connected. —Capabilities of the client device. —Wireless link data transfer speed. —Enables or disables the LEDLight Emitting Diode. LED is a semiconductor light source that emits light when an electric current passes through it. indication on the corresponding AP to which the client is connected. |
AI Insights
The tab displays information about client performance and connectivity issues. AI Insights are displayed for a selected time period based on the time selected in . The user can select 3 hours, 1 week, 1 day, or 1 month to view the insight data. are categorized in high, medium, and low priorities depending on the number of occurrences.
Red—High priority
Orange—Medium priority
Yellow—Low priority
Each insight report specific details on the occurrences of these events for ease in debugging. For more information, see The AI Insights Dashboard
The client page displays the following insights:
Clients had excessive Wi-Fi security key-exchange failures
Clients had excessive 802.1x authentication failures
Clients had DHCP server connection problems
Clients had an unusual number of MAC authentication failures
Connectivity
The page displays information about the overall throughput usage, roaming events, and latency. The following table describes the information displayed in each section:
Section |
Description |
Displays the incoming and outgoing throughput traffic for the client during a specific time range. By default, the graph on the pane is plotted for a time range of 3 hours. To view the graph for a different time range, click the link. You can choose to view the graph for a time period of 3 hours, 1 day, 1 week, 1 month, or 3 months. |
Displays call detail records for the client if any. To view this data, ensure that the application service is enabled on the APs. The table displays the following information for the client: —Start time of the call. —Time at which the call ended. —Type of the call. For example, audio or video. —Application protocol used for the call. —Type of connection used to make a call. For example, call from Wi-FiWi-Fi is a technology that allows electronic devices to connect to a WLAN network, mainly using the 2.4 GHz and 5 GHz radio bands. Wi-Fi can apply to products that use any 802.11 standard. to an external device. —Quality of the call. —Status of the session. |
Displays the details of a roaming event and the latency of the client. When a wireless client roams between two APs, the destination AP creates an event. By default, the table displays data for the last 3 hours. To view the table for a different time range, click the link. You can choose to view the data for a time period of 3 hours, 1 day, 1 week, 1 month, or 3 months. The displays two views, grid view and trend view. The grid view displays the following information: —Displays the time of occurrence of the client roaming/ association events. —The SSID to which the client is connected. —Roaming Latency in milliseconds between source and destination AP. —The BSSIDBasic Service Set Identifier. The BSSID identifies a particular BSS within an area. In infrastructure BSS networks, the BSSID is the MAC address of the AP. In independent BSS or ad hoc networks, the BSSID is generated randomly. of the destination AP. —AP to which the client was connected. —AP to which the client is connected. —The type of roam. —Radio band on which the client is connected. —Received Signal Strength Indicator (RSSIReceived Signal Strength Indicator. RSSI is a mechanism by which RF energy is measured by the circuitry on a wireless NIC (0-255). The RSSI is not standard across vendors. Each vendor determines its own RSSI scale/values.) on the client, estimated measure of power level that the client is receiving from the AP. The trend view displays a chart that shows the percentage of high latency roaming events, total roaming events, and the number of high latency roaming events at a particular instance based on the value selected in the . Clicking on the chart brings you back to the grid view. |
Location
The tab displays the current physical location of the client device on the floor map.
UCC
The tab displays the detailed call records for the client if any. To view this data, ensure that the application service is enabled on the APs. The following table describes the information displayed in each session:
Section |
Description |
Displays the total number of calls. The call quality is displayed as: Good Fair Poor Unknown |
Displays the health of the client. |
Displays the type of the call or session. For example, audio, or video, or desktop sharing. |
Displays the quality of the call. |
AirGroup
The displays the details of the servers a client is connected to. The following table describes the information displayed in each session:
Section |
Description |
Displays the host name. |
Displays the MAC address of the server the client is connected to. |
Displays the IP address. |
Displays the user role assigned to the client. |
Displays the type of service. |
Displays the connected VLAN details. |
Displays the network the client is connected to. Name of the AP that broadcasts the SSID to which the client is connected. |
To view the details of a client connected to the wired network:
5. Click the name of the wired client to open the corresponding page. If there are many clients connected to the network, click to filter the clients connected to the wired network, enter the client name in the column, and click the client name.
Client Summary Bar
Field |
Description |
MAC address and connection status |
Name of the controller to which the client is connected. Click the name of the controller to view the device details page. |
Wired Client Details
The wired client details page displays the client details summary and the client sessions information.
Wired Client Summary
The wired client summary page consists the following tabs:
Overview
The tab consists of three sections. The following table describes the information displayed in each section:
Section |
Description |
Displays the data path of the client in the network. Click the device icon to view the corresponding device details page. The data path can be one of the following: > > > > > > > > > > > > > > > > |
Displays the following information: —User name of the client. —Hostname of the client. —Type of the client device. —IP address of the client. —Manufacturer of the client device. —Date and time since when the client is connected. —Operating system running on the client device. |
Displays the following information: —VLAN ID on which the client is connected to the AP. —Controller role associated to the client. —Controller port to which the client is connected. |
Connectivity
The tab displays information about the incoming and outgoing throughput traffic for the client during a specific time range. By default, the graph on the pane is plotted for a time range of 3 hours. To view the graph for a different time range, click the link. You can choose to view the graph for a time period of 3 hours, 1 day, 1 week, 1 month, or 3 months.
UCC
The tab displays the detailed call records for the client if any. To view this data, ensure that the application service is enabled on the Controller. The following table describes the information displayed in each session:
Section |
Description |
Client Sessions
The client sessions page consists of the firewallFirewall is a network security system used for preventing unauthorized access to or from a private network. session details for the client connected to an AP or a Controller. The page displays information filtered by the IP address of the client. The pane displays the total number of sessions and the time stamp of when the page was last refreshed.
The Sessions table lists the details of each session. By default, the table displays the following columns: , , , , , , , , , and . Click the ellipsis icon to perform additional operations:
—Adjusts the column width of the table to fit the page evenly.
—Resets the table view to the default columns.
If a filter icon appears next to the column header, click it and enter the filter criteria or select a filter criteria. The following table describes the information displayed in each session:
Section |
Description |
Displays the list of applications. |
Displays the source IP address. |
Displays the destination IP address. |
Displays the communication protocol used. |
Displays the source port number. |
Displays the destination port number. |
Displays the application specific action. |
Displays the active flags |
Displays the number of packets. |
Displays the total number of bytes. |
Displays the connection state of the application. The state can either be Denied, Active, or Inactive. |
Displays the start time. |
Displays the receive time. |
Displays the WebCC category. |
Displays the WebCC reputation. |
Displays the WebCC score. |
Displays the application category. |
For details on the AP client sessions refer, Access Point > Clients > Clients.
Applications
To view application usage metrics for the client connected to the wired network, enable .
The tab consists of two sections:
—Displays a table with details on the client traffic flow to and from various applications. Click the bar graph icon to view bar graphs indicating the traffic flow.
—Displays a table with details on client traffic flow and their data usage by various websites. Click the bar graph icon to view bar graphs indicating the data usage by various websites.
For more information about enabling , list of supported Instant APs, and the data displayed on the and sections, see Application Visibility.
Events
The page displays the details of events generated by the AP and client association. By default, the table displays the following columns: , , and . Click the ellipsis icon to perform additional operations:
If a filter icon appears next to the column header, click it and enter the filter criteria or select a filter criteria. The following table describes the information displayed in each event:
Section |
Description |
Displays the time at which the event occurred. |
Displays the type of the event. |
Displays the detailed description of the event. |
Displays the MAC address of the device. |
Displays the BSSID. |
To download events into a CSVComma-Separated Values. A file format that stores tabular data in the plain text format separated by commas. format, click the download button. Aruba Central (on-premises) generates the CSV report of all the events for the selected client.
Tools
The page is automatically filtered based on the client you select. This enables network administrators to perform checks on the client and debug client connectivity issues. For more information, see Using Troubleshooting Tools.
