All Clients
The page provides a summary view of all the clients connected to the network. You can filter clients based on the network the clients are connected to. The page displays key client information and also allows you to view a specific client detail page.
By default, the page displays a unified list of clients for the selected group. The list of clients is populated for a time range of 3 hours. To view the list of clients for a different time range, click the link and select the required time period. Total data usage for the selected time period is displayed above the client summary bar.
To filter clients based on the device to which the clients are connected, select the device type from the drop-down list:
—Displays a unified list of clients connected to the network.
—Displays a list of clients connected to the Instant AP.
—Displays a list of clients connected to the switch.
—Displays a list of clients connected to the Aruba Controller.
The wired client will show up in the page only if the client is connected to an Aruba 2540 Series, Aruba 2920 Series, Aruba 2930F Series, Aruba 2930M Series, Aruba 3810 Series, or Aruba 5400R Series switch. |
To filter clients based on the network to which the clients are connected, click the network type from the bar:
—Displays a list of clients connected to the wireless network.
—Displays a list of clients connected to the wired network.
The table lists the details of each client. By default, the table displays the following columns: , , , , , ,, , , and . Click the ellipsis icon to perform additional operations:
—Downloads the client details in the .csv file format.
—Selects all columns.
—Resets the table view to the default columns.
If a filter icon appears next to the column header, click it and enter the filter criteria or select a filter criteria. For example, in the column, enter the name of the client and in the column, select from one of the predefined filter criteria: , , or .
Column |
Applicability |
Description |
Unified AP Switch Controller |
Username, hostname, or MACMedia Access Control. A MAC address is a unique identifier assigned to network interfaces for communications on a network. address of the client. Click the client name to view the client details page. |
Unified AP Switch |
Client connection status. Use the filter option to view the following: Connected clients Offline clients Failed clients. Hover your mouse over the status to view: Client name IP address —Date and time at which the client connected. —Last seen time. —Failure reason and last seen time. |
Unified AP Switch |
IP address of the client. |
VLANVirtual Local Area Network. In computer networking, a single Layer 2 network may be partitioned to create multiple distinct broadcast domains, which are mutually isolated so that packets can only pass between them through one or more routers; such a domain is referred to as a Virtual Local Area Network, Virtual LAN, or VLAN. of the device to which the client is connected. |
Unified |
AP name, Switch name, or Controller name. This is the first layer 2 hop for the client. If the device does not have a name, the MAC address is displayed. |
Unified |
Displays SSIDService Set Identifier. SSID is a name given to a WLAN and is used by the client to access a WLAN network. for wireless clients and port number for wired clients. |
Unified AP |
Role assigned by the Instant AP. |
Unified Controller |
Role assigned by the Aruba Controller. |
Unified AP Controller |
Client health. The value can be one of the following: —71-100. —31-70. —0-30. |
Group name of the device managed by Aruba Central. |
Name of the site in which the devices managed by Aruba Central are installed. |
MAC address of the client. |
Host name of the client. |
Username of the client. |
Unified AP |
Security mode used by the client. |
Unified AP |
Authentication type. |
Unified AP |
IPv6 address of the client. |
Unified AP |
Client capabilities. |
Total data usage for the selected time period. |
Operating system of the client. |
Date and time at which the client was last seen. |
Date and time since when the client was connected. |
Unified AP |
Name of the Instant AP. |
Unified AP |
MAC address of the Instant AP. |
Unified AP |
Last connected channel and bandBand refers to a specified range of frequencies of electromagnetic radiation.. |
Unified Switch |
Name of the switch. |
Unified Switch Controller |
Port number of the switch. |
Name of the Aruba Controller. |
