AOS-CX VSF Stack
A switch stack is a set of switches that are interconnected through stacking ports. The switches in a stack elect a primary switch called Conductor and a backup switch as Standby. The remaining switches become Members of the stack. The following table lists the AOS-CX switches that support stacking:
Switch Platform |
Maximum Number of Stack Members |
Minimum Supported Version |
Recommended Version |
Supported Stack Type |
Supported Configuration Group Type for Stacking (UI / Template) |
AOS-CX 6200 Switch Series |
8 |
10.04.3000 |
10.05.0010 |
VSF |
Template only |
AOS-CX 6300 Switch Series |
10 |
10.04.3000 |
10.05.0010 |
VSF |
Template only |
For more information on topology and configuration of switch stacks, see the ArubaOS-CX Virtual Switching Framework (VSF) Guide for the respective switch series.
This section contains the following topics:
- AOS-CX Switch Stacking Functions Supported in Aruba Central
- AOS-CX Switch Stacking Functions Not Supported in Aruba Central
- General Recommendations
- Configuring AOS-CX Switch Stacks
- Monitoring AOS-CX Switch Stacks
- Viewing AOS-CX Switch Stacks in Site Topology
Aruba Central supports only a few functions related to AOS-CX switch stack, such as onboarding a stack to Aruba Central and replacing member switches having the same model and part number. All other stacking related activities, such as creating a stack, deleting or adding a new member to the stack, must be performed offline, that is, outside Aruba Central.
Following stack related functions are supported on Aruba Central:
The AOS-CX switch stack must be setup using the CLI or the AOS-CX mobile application before onboarding on to Aruba Central.
- Onboarding a VSF stack to Aruba Central
- Replacing a VSF member with same model and part number
- Rebooting a member—Conductor, standby, and other members
- Splitting or merging a stack
- VSF switchover
Following stack related functions are not supported on Aruba Central and must be performed outside Aruba Central, after taking the stack offline from Aruba Central:
- Setting up an AOS-CX switch stack
- Adding a new member to an existing stack
- Adding a new VSF link
- Deleting a member from the VSF stack
- Reassigning standby or other members to the stack
For information on these configurations, see the ArubaOS-CX Virtual Switching Framework (VSF) Guide for the respective switch series and the ArubaOS-CX VSF Best Practices document.
Following are the general recommendations to note when configuring an AOS-CX switch stack:
- To maximize available VSF link bandwidth, use Aruba 50G DAC cables for VSF links.
- All VSF link ports in a stack must operate at the same speed (10G, 25G, or 50G).
- For maximum stack resiliency, the primary and secondary members should be the same switch models with redundant power supplies connected to different circuits. This is required to minimize the probability that a single-source power failure will disable both the stack conductor and standby.
- A secondary member must always be defined to assume the VSF standby role.
- The out-of-bandBand refers to a specified range of frequencies of electromagnetic radiation. management (OOBM) ports on the primary and secondary members must be connected to each other, either directly or through a dedicated management network. This is required to utilize the VSF split detection, which must always be enabled.
You can perform the following functions in Aruba Central for AOS-CX switchvstacks:
- Onboarding the stack to Aruba Central.
For information, see Onboarding AOS-CX VSF Stack to Aruba Central.
- Replace a stack member with the same model and part number.
For information, see Replacing an AOS-CX VSF Stack Member (Same Model and Part Number).
- Remove a stack member.
For information, see Removing an AOS-CX VSF Stack Member.
See Monitoring Switches and Switch Stacks.
See Monitoring Sites in the Topology Tab.
