Configuring AOS-Switches in UI Groups
This section describes the configuration and viewing procedures for the switches in the UI groups.
Aruba Central does not support adding pre-configured switches to a UI group. Pre-configured switches that have pre-assigned UI switch groups are added to the Unassigned Devices group. To provision a pre-configured switch to a UI group or move a switch from a template group to a UI group, complete the following steps:
- Clear the switch configuration.
- Delete the device from Aruba Central.
- Provision the switch as a new device in a UI group.
To configure or view properties of the switches provisioned in UI groups, perform the following procedure:
- In the app, select one of the following options:
- To select a switch group in the filter:
- Set the filter to a group containing at least one switch.
The dashboard context for the group is displayed.
- Under , click > .
- To select a switch in the filter:
- Set the filter to or a group containing at least one switch.
- Under , click > .
A list of switches is displayed in the view.
- Click a switch under .
The dashboard context for the switch is displayed.
- Under , click .
The tabs to configure the switch is displayed.
- Click the configuration icon to edit the switch properties. Tabs to access different configuration pages are displayed.
The following table describes the different configuration pages and their functions.
