Verifying Device Configuration Status
Aruba Central provides an audit dashboard for reviewing configuration changes for the devices provisioned in UI and template groups. The menu option under > allows you to view the configuration template errors, configuration sync, and device level configuration overrides.
Viewing Configuration Audit Page
To access the page:
- For APs:
- In the app, use the filter bar to select a group or device.
- Under > > .
- Click the
configuration icon and click - Click.
- For switches:
- Under > > .
- Click the
Configuration Synchronization Errors
The devices managed by Aruba Central receive the configuration changes from Aruba Central. Occasionally, an Aruba Central-managed device may fail to receive a configuration change from Aruba Central. Such instances are marked as in the dashboard. If the condition persists, contact Aruba Technical Assistance.
Local Overrides
In Aruba Central, devices are assigned to groups that serve as the primary configuration elements. Occasionally, based on the network provisioning requirements, the administrators may need to modify the configuration of a specific device in a group. As these modifications override the configuration settings that the device has inherited from the group, Aruba Central marks these as local overrides.
Viewing Status for a Template Group
On selecting a template group, the page displays the options listed in Table 1:
Data Pane Content |
Description |
Provides details of the number of devices with template errors for the selected template group. Devices deployed in the template group are provisioned using configuration templates. If there are errors in the templates or variable definitions, the configuration push to the devices fails. Aruba Central records such failed instances as template errors and displays these errors on the page. To view a complete list of errors, click . The window allows you to view and resolve the template errors issues if any for the devices in the group. |
Provides details of the number of devices with configuration sync errors for the selected template group.
To view the configuration sync errors, click . The Configuration Sync Issues window is displayed with the following tabs: —Displays the configuration changes that are not synched with the switch. —Displays the running configuration on the switch.
To resolve the configuration sync errors, click . Aruba Central will attempt to synchronize the configuration with the switch again. Click in the confirmation window. To check whether the configuration was synchronized and pushed to the switch, see the Audit Trail page. |
Allows you to view and edit devices that are set to managed or monitored operation mode. —Click the link. The window is displayed with the list of devices operating in the managed mode. To change the device operation mode to monitored, click . —Click the link. The window is displayed. To change the device operation mode to managed, click . |
Allows you to create a backup of templates and variables applied to the devices in the template group. . —Allows you to create a new backup of templates and variables applied to the devices in the template group. |
The table provides the following device information for the selected group: —The name of the device. —The type of the device. —Indicator showing configuration sync errors. —Indicator showing configuration template errors for the devices deployed in template groups. |
Viewing Status for Devices Assigned to a Template Group
On selecting a device that is provisioned in a template group, the page displays the options listed in Table 1:
Viewing Configuration Status for a UI Group
On selecting a UI group, the page displays the options listed in Table 1.
Data Pane Content |
Description |
Displays the number of devices with configuration sync errors for the selected UI group.
Displays the number of devices with local overrides. To view a complete list of overrides, click the link. The window is displayed. To preserve the overrides, click . To remove the overrides, select the group name with local override, click and click . |
The table provides the following device information for the selected group: —The name of the device. —The type of the device. —The status of the auto commit state for all the devices within the group. —Indicator showing configuration sync errors. —Indicator showing configuration overrides for the devices deployed in UI groups. |
Viewing Configuration Status for Devices Assigned to a UI Group
On selecting a device assigned to a UI group, the page displays the options listed in Table 1.
Data Pane Content |
Description |
Displays the number of devices with configuration sync errors for the selected device.
Displays the number of local overrides. To view a complete list of overrides, click . The window is displayed. The overrides are grouped based on the features that are configured in the UI and are displayed as drop-down sections. For example, all overrides for IGMPInternet Group Management Protocol. Communications protocol used by hosts and adjacent routers on IP networks to establish multicast group memberships. are listed under a separate drop-down with the heading IGMP. To preserve the overrides, click . To remove the overrides, click , and click . |
