Aruba Central Online Help
You are here: Home > Getting Started with Aruba Central (on-premises) > Connect Access Points to Aruba Central
Connecting Aruba APs to Aruba Central
The Aruba IAPs have the ability to automatically provision themselves and connect to Aruba Central (on-premises) once they are powered on.
To provision IAPs:
  1. Connect your IAP to the provisioning network through PSKPre-shared key. A unique shared secret that was previously shared between two parties by using a secure channel. This is used with WPA security, which requires the owner of a network to provide a passphrase to users for network access. onboarding.
  2. Wait for the device to obtain an IP address through DHCPDynamic Host Configuration Protocol. A network protocol that enables a server to automatically assign an IP address to an IP-enabled device from a defined range of numbers configured for a given network. .
  3. Observe the LEDLight Emitting Diode. LED is a semiconductor light source that emits light when an electric current passes through it. indicators. For more information, refer to the AP Installation Guide.
When an IAP identifies Aruba Central (on-premises) as its management entity, it connects to Aruba Central (on-premises) and shows up as a connected device in Aruba Central (on-premises).
