Configuring RADIUS Server Settings on AOS-Switches
Aruba Central allows you to configure RADIUSRemote Authentication Dial-In User Service. An Industry-standard network access protocol for remote authentication. It allows authentication, authorization, and accounting of remote users who want to access network resources. (Remote Authentication Dial-In User Service) server settings on switches.
To configure a RADIUS server, complete the following steps:
- In the app, select one of the following options:
- To select a switch group in the filter:
- Set the filter to a group containing at least one switch.
The dashboard context for the group is displayed.
- Under , click > .
- Click the icon to view the switch configuration dashboard.
- To select a switch in the filter:
- Set the filter to or a group containing at least one switch.
- Under , click > .
A list of switches is displayed in the view.
- Click a switch under .
The dashboard context for the switch is displayed.
- Under , click .
The tabs to configure the switch is displayed.
- Click > . The RADIUS page is displayed.
- Click + to add a RADIUS server. The Add RADIUS Server window is displayed.
- Configure the following parameters.
Name |
Description |
Value |
The IP address of the RADIUS server. |
The destination port for authentication requests to the specified RADIUS server. |
Default: 1812 |
The encryption key for use during authentication sessions with the specified RADIUS server. |
Retype the shared key. |
Indicates whether the dynamic authorizationDynamic authorization refers to the ability to make changes to a visitor account’s session while it is in progress. This might include disconnecting a session or updating some aspect of the authorization for the session. is enabled. When enabled, the RADIUS server can dynamically terminate or change the authorization parameters used in an active client session on the switch. |
Toggle switch to the on or off position |
Indicates whether the ClearPassClearPass is an access management system for creating and enforcing policies across a network to all devices and applications. The ClearPass integrated platform includes applications such as Policy Manager, Guest, Onboard, OnGuard, Insight, Profile, QuickConnect, and so on. server is enabled on the RADIUS server. |
- Click .
Editing a RADIUS Server Settings
To edit a RADIUS server, point to the row for the server, and click the edit icon.
Deleting a RADIUS Server Settings
To delete a RADIUS server, point to the row for the server, and click the delete icon.
