Configuring VLANs on AOS-Switches
- Port-based VLANs—In the case of trusted interfaces, all untagged traffic is assigned a VLAN based on the incoming port.
- Tag-based VLANs—In the case of trusted interfaces, all tagged traffic is assigned a VLAN based on the incoming tag.
The Aruba Mobility Access Switch also supports the following types of VLANs:
- Voice VLANs—You can use voice VLANs to separate voice traffic from data traffic when the voice and data traffic are carried over the same EthernetEthernet is a network protocol for data transmission over LAN. link.
- MACMedia Access Control. A MAC address is a unique identifier assigned to network interfaces for communications on a network. -based VLANs—In the case of untrusted interfaces, you can associate a client to a VLAN based on the source MAC of the packet. Based on the MAC, you can assign a role to the user after authentication.
Adding VLAN Details
By default, all ports in the Switches are assigned to VLAN 1. However, if the ports are assigned to different VLANs, the VLANs page displays their details.
To add a VLAN, complete the following steps:
- In the app, select one of the following options:
- To select a switch group in the filter:
- Set the filter to a group containing at least one switch.
The dashboard context for the group is displayed.
- Under , click > .
- Click the icon to view the switch configuration dashboard.
- To select a switch in the filter:
- Set the filter to or a group containing at least one switch.
- Under , click > .
A list of switches is displayed in the view.
- Click a switch under .
The dashboard context for the switch is displayed.
- Under , click .
The tabs to configure the switch is displayed.
- Click > . The VLANs page is displayed.
- In the accordion, click + to add a VLAN and configure the following parameters.
Name |
Description |
Value |
The name of the VLAN. |
A string |
The method of IP assignment. The static option is displayed only at the device level. The options to assign Primary VLAN and Management VLAN are displayed only when you select Static or DHCPDynamic Host Configuration Protocol. A network protocol that enables a server to automatically assign an IP address to an IP-enabled device from a defined range of numbers configured for a given network. . |
, , or Default: |
The IP address for static IP assignment. This field is enabled only when you select from the drop-down. |
IPv4 address |
The netmask for static IP assignment. This field is enabled only when you select from the drop-down. |
IPv4 address |
Indicates whether the switch is configured as the DHCP server on the VLAN. This field is enabled only when you select from the drop-down. You can enable option only when there are no DHCP Helper IP addresses configured. |
Toggle switch to the on or off position |
IP address of the DHCP helper server for that VLAN. You can configure a maximum of 16 DHCP helper IP addresses for each VLAN. You can configure DHCP Helper IP addresses only when option is disabled. |
IPv4 address |
Indicates whether support for voice VLANs are enabled for the VLAN interface. |
Indicates whether the VLAN is assigned as the primary VLAN for the switches. To assign primary VLAN, at least one tagged or untagged port should be configured. This is a mandatory field. |
Indicates whether the VLAN is assigned as the management VLAN for the switches. |
Default gateway for static IP assignment. This field is enabled only when you select Static from the IP Assignment drop-down. |
IPv4 address |
Indicates whether jumbo packet handling is enabled for the VLAN interface. |
The security policy that you want to apply for the inbound traffic. |
The security policy that you want to apply for the outbound traffic. |
The security policy that you want to apply for the bridged and routed inbound packets on the VLAN. |
The security policy that you want to apply for the bridged and routed outbound packets on the VLAN. |
- To configure the VLAN ports, complete the following steps:
- In the table, select the port number(s).
- Select any of the following port modes:
- To assign the VLAN to a trunk group, select the trunk group in the table.
- Click .
- Click .
Editing the VLAN Details
To edit the details of a VLAN, point to the row for the VLAN, and click the edit icon in the column, and configure the parameters.
Deleting VLAN Details
To delete the VLAN details, complete the following steps:
- Ensure that the VLANs are not tagged to any ports.
- Point to the row for the VLAN, and click the edit icon in the column.
VLAN 1 is the primary VLAN and cannot be deleted.
Configuring DHCP Relay Settings
You can configure a switch as a DHCP relay agent for transmitting DHCP messages between the DHCP server and client. You can also configure the option-82 feature for the switch to include DHCP relay information in the forwarded DHCP request messages.
To configure a switch as a DHCP relay agent, complete the following steps:
- Under , click > .
- Under , click > .
- Under , click .
- Expand the accordion.
- To enable DHCP relay, move the toggle switch to the on position.
option is enabled by default.
- To enable option-82 feature, move the toggle switch to the on position.
- Click .
