Configuring Tunnel Node Server on AOS-Switches
Aruba Central allows you to configure tunneled node on switches. The tunneled node connects to one or more client devices at the edge of the network and then establishes a secure Generic Routing Encapsulation (GREGeneric Routing Encapsulation. GRE is an IP encapsulation protocol that is used to transport packets over a network.) tunnel to the controlling concentrator server. You can configure either Port-Based Tunnel or User-Based Tunnel using UI groups.
To modify the reserved VLANVirtual Local Area Network. In computer networking, a single Layer 2 network may be partitioned to create multiple distinct broadcast domains, which are mutually isolated so that packets can only pass between them through one or more routers; such a domain is referred to as a Virtual Local Area Network, Virtual LAN, or VLAN., change the mode to and click, then change the mode back to .
The configuration cannot be modified when tunneled clients are active.
To configure a tunneled node on the switch, complete the following steps:
- In the app, select one of the following options:
- To select a switch group in the filter:
- Set the filter to a group containing at least one switch.
The dashboard context for the group is displayed.
- Under , click > .
- Click the icon to view the switch configuration dashboard.
- To select a switch in the filter:
- Set the filter to or a group containing at least one switch.
- Under , click > .
A list of switches is displayed in the view.
- Click a switch under .
The dashboard context for the switch is displayed.
- Under , click .
The tabs to configure the switch is displayed.
- Click > . The Tunnel Node Server page is displayed.
- Configure the following parameters.
| Name | Description | Value |
The mode of tunneling from the drop-down:
, , or |
The IP address of the primary gateway. |
A valid IPv4 address |
The IP address of the backup gateway. This field is optional. |
Reserved VLAN |
The reserved VLAN ID to tunnel traffic to an Aruba controller. This field is available only for User-Based tunnel. The default VLAN or a VLAN that is already configured cannot be used as a reserved VLAN. To view the list of configured VLANs, navigate to > . |
Numeric value |
- Click .
For more detailed information, refer to Dynamic Segmentation white paper at https://www.arubanetworks.com/assets/so/SO_Dynamic-Segmentation.pdf
