Configuring or Viewing the Switch Properties
When you add a switch to a group, the switch inherits the configuration of the group.
It is not recommended to add a switch with an existing configuration to a group that already has a defined configuration. Aruba Central permits device-level overrides, however the overrides are resolved or preserved based on the requirements.
You can create a new group and add a pre-configured switch to that group so that the group inherits the configuration of the switch. If the switch inherits the group configuration, the configuration parameters are already defined. If required, you can edit these parameters. All factory default switches are provisioned in a new group and these parameters can also be defined at the group level.
To edit the configuration parameters for the switch in an UI group, complete the following steps:
- In the app, select one of the following options:
- To select a switch group in the filter:
- Set the filter to a group containing at least one switch.
The dashboard context for the group is displayed.
- Under , click > .
- Click the icon to view the switch configuration dashboard.
- To select a switch in the filter:
- Set the filter to or a group containing at least one switch.
- Under , click > .
A list of switches is displayed in the view.
- Click a switch under .
The dashboard context for the switch is displayed.
- Under , click .
The tabs to configure the switch is displayed.
- Click the tab.
The page is displayed with the following information:
Name |
Description |
Value |
MACMedia Access Control. A MAC address is a unique identifier assigned to network interfaces for communications on a network. address of the switch. |
Property inherited from the switch. |
Name of the host. |
A string. |
Method of IP assignment as static or DHCPDynamic Host Configuration Protocol. A network protocol that enables a server to automatically assign an IP address to an IP-enabled device from a defined range of numbers configured for a given network. . |
or . |
IP address for static IP assignment. |
Netmask for static IP assignment. |
Default gateway for static IP assignment. |
Location of the switch. |
For example: Portland, Oregon. |
Email address or phone number. |
For example: admin@xyzcompany.com. |
- To edit the switch configuration parameters, click the edit icon.
The Edit Switches window is displayed.
- Edit the required parameters.
You can edit only Hostname, Location, and Contact information.
- Click .
- Click .
