The Label Dashboard
In the Network Operations app, the label dashboard is displayed when the filter is set to any of the options under Labels. The label dashboard displays information related to all devices configured for that label in Aruba Central.
Table 1: Contents of the Label Dashboard
Left Navigation Menu
First-Level Tabs
Description
Manage > Devices
All Devices
Displays details such as the bandwidth usage, client count, top APs by usage, top 5 clients, top AP clusters by usage, top AP clusters by clients, and WLANWireless Local Area Network. WLAN is a 802.11 standards-based LAN that the users access through a wireless connection. network details. By default, the graphs are plotted for a time range of 3 hours. To view the graphs for a different time range, click the Time Range filter.
For more information, see Global—Summary
Access Points
Displays the access points information in the following views:
Summary view: Monitoring APs in Summary View
List view: Monitoring APs in List View
Switches
Displays the switches information in the following views:
Summary view: Monitoring Switches in Summary View
List view: Monitoring Switches in List View
Controllers
Displays the controller information in the following view:
Summary view: Controller > Overview > Summary
Manage > Clients
Clients
Displays information about all the clients connected to the devices configured for the group.
For more information, see All Clients.
Manage > Applications
UCC
Displays a variety of charts and lists that allow you to assess the quality of calls in the network.
For more information, see Unified Communications.
Manage > Security
RAPIDs
Identify and act on interfering devices that can be later considered for investigation, restrictive action, or both. Once the interfering devices are discovered, Aruba Central sends alerts to the network administrators about the possible threat and provides essential information needed to locate and manage the threat.
For more information, see RAPIDS.
Analyze > Alerts and Events
Alerts & Events
Displays all types of alerts and events generated for events pertaining to device provisioning, configuration, and user management.
For more information, see Alerts & Events.
Analyze > Tools
Network Check
Device Check
Commands
Enables network administrators and users with troubleshooting permission to perform troubleshooting or diagnostics tests on devices and networks managed by Aruba Central.
For more information, see Using Troubleshooting Tools.
Analyze > Reports
Reports
Enables you to create various types of reports. You can create recurrent reports or configure the reports to run on demand.
For more information, see Reports .
