About the Network Operations App User Interface
The Network Operations app is one of the apps in Aruba Central that helps to manage, monitor, and analyze your network. you can manage your respective accounts end-to- end. Here, the customers have complete access to their accounts. You can also provision and manage the accounts.
The following image displays the navigational elements of the Network Operations app.
Figure 1  Navigation Elements of the Network Operations App
Callout Number
Description
1
Filter to select an option under Group, Label, Site. For all devices, select Global. A corresponding dashboard is displayed.
2
Item under the left navigation contextual menu. The menu is dependent on the filter selection.
3
First-level tab on the dashboard.
4
Second-level tab on the dashboard.
5
Dashboard content for the selected view and filter. For example, the current dashboard in the image displays the UCC tab under Manage > Applications in the List view for the Global filter.
6
Time range filter. This is displayed for selected dashboards only.
7
List view to display tabular data for the selected filter. This is displayed for selected dashboards only.
8
Summary view to display charts for the selected filter. This is displayed for selected dashboards only.
9
Config view to enable configuration options for the selected filter. This is displayed for selected dashboards only.
Types of Dashboards in the Network Operations App
The Network Operations app uses a filter to set the dashboard context for the app. The menu for the left navigation pane changes according to the selected filter value. Selecting any item on the left navigation pane displays a corresponding dashboard. Accordingly, for different values of the filter, the content displayed for the left navigation menu and the dashboard context differs. The following table lists down all the available dashboards and the link to the detailed description of each type of dashboard.
Table 1: Types of Dashboards
Link to the Dashboard
Filter Value and Dashboard Description
The Global Dashboard
When the filter is set to Global (for standard enterprise modes) or All Groups (for managed service modes), the dashboard context displayed is for all available devices registered to the specific Aruba Central account. This is called the global dashboard.
The Group Dashboard
When the filter is set to a specific group, the dashboard context displayed is only for the devices that are configured as part of that group. This is called the group dashboard.
The Site Dashboard
When the filter is set to a specific site, the dashboard context displayed is only for the devices that are configured as part of that site. This is called the site dashboard.
The Label Dashboard
When the filter is set to a specific label, the dashboard context displayed is only for the devices that are configured as part of that label. This is called the label dashboard.
The Controller Dashboard
When the filter is set to a controller, the dashboard context displayed is only for that specific controller. This is called the controller dashboard. The controller dashboard enables you to manage and monitor a specific controller.
The Access Point Dashboard
When the filter is set to an access point, the dashboard context displayed is only for that specific access point. This is called the access point dashboard. The access point dashboard enables you to manage and monitor a specific access point.
The Switch Dashboard
When the filter is set to a switch, the dashboard context displayed is only for that specific switch. This is called the switch dashboard. The switch dashboard enables you to manage and monitor a specific switch.
The Client Dashboard
In the Network Operations app, the client dashboard is displayed under Manage > Clients for any filter value.
The dashboard for any item on the left navigation menu can have a combination of the following views:
Navigating to the Switch, Access Point, or Controller Dashboard
In the Network Operations app, you can navigate to a device dashboard for a switch, access point, or controller. The device dashboard enables you to monitor, troubleshoot, or configure a single device. In order to do this, complete the following steps:
  1. In the Network Operations app, set the filter to one of the options under Group, Label, or Site. For all devices, set the filter to Global.
  2. 1. Under Manage > Devices, select one of the following options:
    • To view an access point dashboard, click the Access Points tab.
    • To view a switch dashboard, click the Switches tab.
    • To view a controller dashboard, click the Controllers tab.
    The list of devices is displayed in List view.
  3. Click a device listed under Device Name.
    The dashboard context for the specific device is displayed.
    To exit the device dashboard, click the back arrow on the filter.
Workflow to Configure, Monitor, or Troubleshoot in the Network Operations App
The following image displays a flowchart to help you navigate the Network Operations app to complete any task.
Figure 2  Navigation Workflow for Network Operations App
