The Switch Dashboard
In the Network Operations app, the switch dashboard is displayed when the filter is set to a switch.
To navigate to a switch dashboard, see Navigating to the Switch, Access Point, or Controller Dashboard.
Some tabs may not be seen in your dashboard view if you are not an administrator for the Aruba Central (on-premises) account. Also, some tabs or some fields inside tabs are only applicable either for AOS-Switch or AOS-CX switch series.
Table 1: Contents of the Switch Dashboard
Left Navigation Menu
First-Level Tabs
Description
Manage > Overview
Summary
Displays details about a specific switch, including device information, network summary, and port and hardware status. It also displays uplink and usage details. Use the time range filter to change the time period for the displayed information.
See Switch > Overview > Summary.
Hardware
Displays switch hardware details, including status of power supplies and fans, CPUCentral Processing Unit. A CPU is an electronic circuitry in a computer for processing instructions. and memory utilization, and device temperature.
See Switch > Overview > Hardware.
Routing
Displays routing information for the switch, such as, type of route, number of static and connected routes, and distance of the route.
See Switch > Overview > Routing.
NOTE: The Routing tab is displayed only for AOS-Switches.
Manage > Clients
Clients
Displays details about the wired clients that are connected to the switch.
See Switch > Clients > Clients.
Neighbours
Displays details about the devices neighboring the switch.
See Switch > Clients > Neighbours.
Manage > LAN
Ports
Displays details about ports and the LAGs configured in the switch. Also displays information about AOS-CX switch stacks and stack-related errors.
See Switch > LAN > Ports.
For information about AOS-CX switch stack-related errors, see Monitoring AOS-CX Switch Stacks.
PoE
Displays details about PoEPower over Ethernet. PoE is a technology for wired Ethernet LANs to carry electric power required for the device in the data cables. The IEEE 802.3af PoE standard provides up to 15.4 W of power on each port. status, PoE ports, and the power consumption from these ports.
See Switch > LAN > PoE.
VLAN
Displays VLANVirtual Local Area Network. In computer networking, a single Layer 2 network may be partitioned to create multiple distinct broadcast domains, which are mutually isolated so that packets can only pass between them through one or more routers; such a domain is referred to as a Virtual Local Area Network, Virtual LAN, or VLAN. information configured on the switch and details about tagged and untagged ports.
See Switch > LAN > VLAN.
Manage > VSX
VSX
Displays VSX configuration details between AOS-CX switches and the status of the inter-switch link (ISL).
See Switch > VSX.
NOTE: The VSX tab is displayed only for AOS-CX switch series.
Manage > Device
AOS-SwitchConfiguration using UI groups
Enables AOS-Switch configuration in the AOS-S Config view. See Configuring AOS-Switches in UI Groups.
Configuration using UI groups contains the following second-level tabs:
AOS-SwitchConfiguration using templates
See Using Configuration Templates for AOS-Switch Management.
Configuration of AOS-Switches using template groups contains the following second-level tabs:
AOS-Switch Stack—Configuration using templates
Configuration of AOS-Switch stacks using template groups contains the following second-level tabs:
AOS-CXConfiguration using UI groups
Enables AOS-CX configuration in the AOS-CX Config view. See Configuring AOS-CX Switches in UI Groups.
Configuration using UI groups allows you to configure the following features:
AOS-CXConfiguration using MultiEdit mode
Enables AOS-CX configuration using the MultiEdit mode in the AOS-CX Config view. View and edit configuration on the AOS-CX switches using the CLI syntax. You can also apply predefined set of configuration settings such as NAE to the switches. See Using MultiEdit View for AOS-CX.
Configuration using the MultiEdit mode contains the following options:
AOS-CXConfiguration using templates
Enables AOS-CX switch configuration in the AOS-CX view. See Using Configuration Templates for AOS-CX Switch Management.
Configuration of AOS-CX switches using template groups contains the following second-level tabs:
AOS-CX VSF Stack—Configuration
Enables AOS-CX switch stack configuration in the AOS-CX view. See Managing an AOS-CX VSF Stack.
Analyze > Alerts & Events
Alerts & Events
The Alerts & Events tab displays all types of alerts and events generated for events pertaining to device provisioning, configuration, and user management. See Alerts & Events.
You can also configure and enable certain categories of switch alerts.
See Switch Alerts.
Analyze > Audit Trail
Audit Trail
Displays the details of logs generated for all device management, configuration, and user management events triggered in Aruba Central (on-premises).
See Viewing Audit Trail.
Analyze > Tools
Network Check
The Network Check tab allows administrators and users with troubleshooting permission to diagnose issues related to wired network connections.
See Troubleshooting Network Issues.
Device Check
The Device Check tab allows network administrators and users with troubleshooting permission to identify, diagnose, and debug issues on AOS-Switch and AOS-CX switches using predefined tests.
See Troubleshooting Device Issues.
Commands
The Commands tab allows network administrators and user with troubleshooting permission to identify, diagnose, and debug issues on AOS-Switch and AOS-CX switches at an advanced level using commands.
See Advanced Device Troubleshooting.
Analyze > Reports
Reports
The Reports tab allows you to create, manage, and view various reports. You can create recurrent reports, generate reports on demand, or schedule reports to run at a later time.
See Reports .
Maintain > Firmware
Switches
The Switches tab allows the user to view the firmware details and upgrade the devices provisioned in Aruba Central (on-premises).
See Upgrading Device Firmware
