Configuring AOS-CX Switches in UI Groups
You can configure AOS-CX switches that are added to a UI group, using the UI options and MultiEdit mode. You can pre-configure groups in the absence of switches. You can configure 4100i, 6100, 6200, 6300, 8320, 8325, 8360 Switch Series using UI options, MultiEdit mode, and templates. You can configure 6405, 6410, and 8400 Switch Series using only templates.
To configure AOS-CX switches using templates, see Using Configuration Templates for AOS-CX Switch Management.
The UI options and MultiEdit mode are available only when the AOS-CX switches are added to a UI group. The UI options and MultiEdit mode are not available when the AOS-CX switches are added to a template group.
To configure or view the properties of AOS-CX switches that are added to UI groups, complete the following steps:
- In the app, select one of the following options:
- To select a UI group in the filter:
- Set the filter to a UI group.
The dashboard context for the UI group is displayed.
- Under , click > .
- Click the or icon to view the AOS-CX switch configuration dashboard.
- To select a switch:
- Set the filter to or a UI group containing at least one switch.
- Under , click > .
A list of switches is displayed in the view.
- Click an AOS-CX switch under .
The dashboard context for the switch is displayed.
- Under , click .
The AOS-CX UI configuration page is displayed.
The following table describes the different configuration pages and their functions.
- To enable MultiEdit mode, move the toggle switch to the on position.
The page is displayed with the list of devices displayed in the table.
At the device level, the table lists only the switch that you have selected. Also, a pop-up is displayed on the bottom-right corner of the page with the options , , and .
Search for a switch by entering a search query in the field.
For more information about search queries, see Using Device Search on AOS-CX.
The following table describes the options available in the MultiEdit mode of configuring AOS-CX switches.
Table 2: Configuring AOS-CX Switches Provisioned in UI Groups using the MultiEdit Mode
Feature
Description
View and edit configuration on the AOS-CX switches using the CLI syntax. You can also apply predefined set of configuration settings such as NAE to the switches.
View configuration of AOS-CX switches and find differences in the configuration across switches.
Edit configuration for one or more AOS-CX switches in the MultiEdit mode. Edit the entire configuration in a familiar looking CLI with syntax checking, colorization, and command completion.
Apply predefined set of configuration settings such as NAE scripts and device profile to a single or multiple switches.
Search for AOS-CX switches in the table, in the MultiEdit mode, using search queries such as device attributes, wildcard characters, Boolean operators, and by grouping characters.
- To view configuration status, pending changes, and local overrides on the switches, click .
This page allows you to commit the pending changes in a configuration. At the device level, this page allows you to change the auto-commit state of the switch.
For more information, see Using Configuration Status on AOS-CX.
Multiple Browser Tab Support
You can open multiple browser tab sessions of the same Aruba Central (on-premises) instance with different switch group or device pages opened simultaneously. For example, you can open the group configuration of a switch in one browser tab and the device-level configuration of a switch in another browser tab. Aruba Central (on-premises) stores the data from the different browser tabs separately.
However, if you edit the configuration of one AOS-CX switch in the MultiEdit mode in two different browser tab sessions, and try to save the configuration one after the other, the following events occur:
- The configuration that you save first in the editor in any of the two browser tabs is saved on the switch.
- When you try to save the configuration in the editor in the other browser tab, Aruba Central (on-premises) displays a warning that the configuration has been changed outside the current editor.
- If you ignore the warning and continue to save the configuration, Aruba Central (on-premises) overwrites the changes saved earlier with the current changes.
