Managing an AOS-CX VSF Stack
A switch stack is a set of switches that are interconnected through stacking ports. By default, the first member in a stack becomes conductor. You must configure the standby conductor manually and there is no default standby conductor. All the switches in the stack other than the conductor and standby conductor become members.
The following table lists the AOS-CX switches that support stacking.
Switch Platform |
Maximum Number of Stack Members |
Minimum Supported Version |
Recommended Version |
Supported Stack Type |
Supported Configuration Group Type for Stacking (UI / Template) |
AOS-CX 6200 Switch Series |
8 |
10.05.0060 |
10.07.0030 |
VSF |
UI and Template |
AOS-CX 6300 Switch Series |
10 |
10.05.0060 |
10.07.0030 |
VSF |
UI and Template |
AOS-CX 6300 Switch Series [JL762A] Back 2 Front Power Supply SKUStock Keeping Unit. SKU refers to the product and service identification code for the products in the inventory. only |
10 |
10.06.0001 |
10.07.0030 |
VSF |
UI and Template |
For more information on topology and configuration of switch stacks, see the AOS-CX Virtual Switching Framework (VSF) Guide for the respective switch series.
Supported Switch Stacking Functions
The following table lists the functions supported in Aruba Central (on-premises), using UI and template configurations, based on the switch firmware versions.
Firmware Versions |
Functions Supported in Aruba Central |
10.06 and earlier |
10.07 and later |
The other stacking related configurations such as replacing a conductor, replacing a standby conductor, and replacing a stack member must be performed offline, that is, outside Aruba Central. The changes are reflected in Aruba Central.
For information on these configurations, see the AOS-CX Virtual Switching Framework (VSF) Guide for the respective switch series and the ArubaOS-CX VSF Best Practices document.
General Recommendations
The following are the general recommendations to note when configuring an AOS-CX switch stack:
- To maximize available VSF link bandwidth, use the following Direct Attach Copper (DAC) cables for VSF links:
- AOS-CX 6300 Switch Series: 50G
- AOS-CX 6200 Switch Series: 10G
- All VSF link ports in a stack must operate at the same speed (10G, 25G, or 50G).
- For maximum stack resiliency, the conductor and secondary conductor should be the same switch models with redundant power supplies connected to different circuits. This is required to minimize the probability that a single-source power failure will disable both the stack conductor and standby.
- A secondary member must always be defined to assume the VSF standby role.
- The out-of-band management (OOBM) ports on the conductor and secondary conductor must be connected to each other, either directly or through a dedicated management network. This is required to utilize the VSF split detection, which must always be enabled.
Monitoring AOS-CX Switch Stacks
See Monitoring Switches and Switch Stacks.
Viewing AOS-CX Switch Stacks in Site Topology
See Monitoring Sites in the Topology Tab.
This section contains the following topics:
- Onboarding AOS-CX VSF Stack to Aruba Central (on-premises)
- Configuring AOS-CX VSF Stacks Using UI Groups
- Configuring AOS-CX VSF Stacks Using Template Groups
- Replacing an AOS-CX VSF Stack Member
- Removing an AOS-CX VSF Stack Member Using UI
- Changing an AOS-CX VSF Stack to Standalone Switches on page 1
- Monitoring AOS-CX Switch Stacks
