Configuring AOS-Switches in UI Groups
This section describes the configuration and viewing procedures for the switches in the UI groups.
Aruba Central (on-premises) does not support adding pre-configured switches to a UI group. Pre-configured switches that have pre-assigned UI switch groups are added to the Unassigned Devices group. To provision a pre-configured switch to a UI group or move a switch from a template group to a UI group, complete the following steps:
- Clear the switch configuration.
- Delete the device from Aruba Central (on-premises).
- Provision the switch as a new device in a UI group.
To configure or view properties of the switches provisioned in UI groups, perform the following procedure:
- In the app, select one of the following options:
- To select a switch group in the filter:
- Set the filter to a group containing at least one switch.
The dashboard context for the group is displayed.
- Under , click > .
- Click the AOS-S or icon to view the switch configuration dashboard.
- To select a switch in the filter:
- Set the filter to or a group containing at least one switch.
- Under , click > .
A list of switches is displayed in the view.
- Click a switch under .
The dashboard context for the switch is displayed.
- Under , click .
The tabs to configure the switch is displayed.
- Click the configuration icon to edit the switch properties. Tabs to access different configuration pages are displayed.
The following table describes the different configuration pages and their functions.
Tab |
Function |
Switches |
Configure or view general switch properties, such as, hostname, type of IP addressing, and so on. |
Stacks |
Create stacks, add members, or view stacking details such as stack type, stack id, topology and so on. See AOS-Switch Stack. |
Ports |
Assign or view port properties, such as, PoEPower over Ethernet. PoE is a technology for wired Ethernet LANs to carry electric power required for the device in the data cables. The IEEE 802.3af PoE standard provides up to 15.4 W of power on each port., access policies, and trunk groups. |
PoE |
Configure or view PoE settings for each port. |
Trunk Groups |
Configure or view trunk groups and their associated properties, such as, members of the trunk group, type of trunk group and so on. |
Configure or view VLANs and the associated ports and access policies. |
Spanning Tree |
Configure or view spanning tree protocol and its associated properties. See Enabling Spanning Tree Protocol on AOS-Switches in UI Groups. |
Loop Protection |
Configure or view loop protection and its associated properties. |
Access Policy |
Add or view access policies. |
Configure or view DHCP snoopingDHCP snooping enables the switch to monitor and control DHCP messages received from untrusted devices that are connected to the switch., authorized DHCP servers IP addresses, and their associated properties. |
Port Rate Limit |
View or specify bandwidth to be used for inbound or outbound traffic for each port. See Configuring Port Rate Limit on AOS-Switchesin UI Groups. |
Configure or view RADIUS (Remote Authentication Dial-In User Service) server settings on switches. |
Downloadable User Role |
Enable Downloadable User Role option and configure ClearPassClearPass is an access management system for creating and enforcing policies across a network to all devices and applications. The ClearPass integrated platform includes applications such as Policy Manager, Guest, Onboard, OnGuard, Insight, Profile, QuickConnect, and so on. settings to download user-roles, policy, and class from the ClearPass Policy ManagerClearPass Policy Manager is a baseline platform for policy management, AAA, profiling, network access control, and reporting. With ClearPass Policy Manager, the network administrators can configure and manage secure network access that accommodates requirements across multiple locations and multivendor networks, regardless of device ownership and connection method. server. |
Tunnel Node Server |
Configure or view tunneled node on switches. |
Authentication |
Configure or view 802.1X802.1X is an IEEE standard for port-based network access control designed to enhance 802.11 WLAN security. 802.1X provides an authentication framework that allows a user to be authenticated by a central authority. authentication and MACMedia Access Control. A MAC address is a unique identifier assigned to network interfaces for communications on a network. authentication for switches. |
Configure or view the administrator and operator logins. |
Time |
Configure time synchronization in switches. |
Add or view SNMP community and its trap destination. |
Configure CDP and its associated properties. |
Routing |
Configure or view a specific routing path to a gateway. |
DHCP |
Enable DHCP server and add DHCP pools on switches. |
Configure IGMP and its associated properties. |
IP Client Tracker |
Configure IP Client Tracker to access trusted and untrusted client networks. |
Create QoS traffic policies. define QoS classes and change the priorities of traffic on switches. |
Device Profile |
Configure or view device profile and device identifier settings on switches. See Configuring Device Profile and Device Identifier on AOS-Switches. |
Configuration Audit |
View configuration sync errors and overrides. |
