doc title Help Center
Creating a Group
Aruba Central supports creating groups and assigning devices to groups for the ease of configuration and maintenance. For example, you can create a common group for APs that have similar configuration requirements.
To create a group, complete the following procedure:
1. In the app, set the filter to .
2. Under , click > .
The page is displayed.
3. Enter the .
4. Select the checkbox or checkbox to use a template based group.
5. Enter a password for the group in the text box.
6. Retype the password in the text box.
7. Click . The newly added group is displayed under the filter bar.
