Verifying Device Configuration Status
Aruba Central provides an audit dashboard for reviewing configuration changes for the devices provisioned in UI and template groups. The menu option under > allows you to view the configuration template errors, configuration sync, and device level configuration overrides.
To access the page:
For APs:
a. In the app, use the filter bar to select a group or device.
b. Under > > .
c. Click the
configuration icon and click
d. Click.
For switches:
b. Under > > .
c. Click the
d. Click.
The devices managed by Aruba Central receive the configuration changes from Aruba Central. Occasionally, an Aruba Central-managed device may fail to receive a configuration change from Aruba Central. Such instances are marked as in the dashboard. If the condition persists, contact Aruba Technical Assistance.
In Aruba Central, devices are assigned to groups that serve as the primary configuration elements. Occasionally, based on the network provisioning requirements, the administrators may need to modify the configuration of a specific device in a group. As these modifications override the configuration settings that the device has inherited from the group, Aruba Central marks these as local overrides.
On selecting a group or device from the filter bar, the page displays the options listed in Table 1:
Data Pane Content |
Description |
Displays the number configuration sync errors for the selected template group. To view and resolve the configuration sync errors, click the link. |
Allows you to view and edit devices that are set to managed or monitored operation mode. —Click the link. The pop-up window opens and displays the list of devices operating in the managed mode. To change the device operation mode to monitored, click . —Click the link. The pop-up window opens. To change the device operation mode to managed, click . |
The table provides the following device information for the selected group: —The name of the device. —The type of the device. —Indicator showing configuration sync errors. —Indicator showing configuration template errors for the devices deployed in template groups. |
On selecting a device that is provisioned in a template group, the page displays the options listed in Table 1:
On selecting a UI group, the page displays the options listed in Table 1.
Data Pane Content |
Description |
Displays the number of devices with configuration sync errors for the selected UI group. To view and resolve the configuration sync errors, click the link. |
Displays the number of devices with local overrides. To view a complete list of overrides, click the link. The pop-up window opens. To preserve the overrides, click . To remove the overrides, select the group name with local override, click and click . |
The table provides the following device information for the selected group: —The name of the device. —The type of the device. —Indicator showing configuration sync errors. —Indicator showing configuration overrides for the devices deployed in UI groups. |
On selecting a device assigned to a UI group, the page displays the options listed in Table 1.
