Access Point > Overview > Spectrum
In the access point (AP) dashboard, the tab provides details for all Wifi and non-Wifi devices associated to each radio.
When the radios of Instant Access Point (IAP) are set to spectrum scan mode, the IAP functions as a dedicated full-spectrum RFRadio Frequency. RF refers to the electromagnetic wave frequencies within a range of 3 kHz to 300 GHz, including the frequencies used for communications or Radar signals. monitor, scanning all channels to detect interference from neighboring IAPs or interfering devices such as microwavesElectromagnetic energy with a frequency higher than 1 GHz, corresponding to wavelength shorter than 30 centimeters. and cordless phones. To enable the spectrum scan feature on a specific radio of an AP, see Access Points Configuration Parameters.
The spectrum scan feature is available only on IAP devices running Aruba Instant 8.5.0.1 firmware version and later.
When the spectrum scan feature is enabled, the Instant AP does not provide services to clients. The tab displays the following sections:
Viewing the Overview > Spectrum Tab
To navigate to the tab in the AP dashboard, complete the following steps:
In the app, set the filter to one of the options under , , or . For all devices, set the filter to . Ensure that the filter selected contains at least one active AP.
Under , click > .
A list of APs is displayed in the view.
Click an AP listed under .
The dashboard context for the AP is displayed.
In the AP dashboard context, click the tab. The tab is displayed.
To exit the AP dashboard, click the back arrow on the filter.
Channel Utilization and Quality
Click the icon to view the details corresponding to and radios of the AP. Click the and tabs on the label to view the and graphs for the radios.
- —The graph indicates the percentage of channel utilization for the , , and categories associated to and radios. You can view the following channel metrics when you hover over the bar graph:
Table 1: Channel Utilization Metrics
Metrics
Description
The channel number of the radio.
The percentage of the channel currently available for use.
The percentage of the channel currently being used by interfering devices.
The percentage of the channel currently being used by microwaves. Common residential microwave ovens with a single magnetron are classified as a Microwave. These types of microwave ovens may be used in cafeterias, break rooms, dormitories, and similar environments. Some industrial, healthcare, or manufacturing environments may also have other equipment that functions like a microwave and may also be classified as a Microwave device.
The percentage of the channel currently being used by bluetooth devices. Any device that uses the Bluetooth protocol to communicate in the 2.4 GHzGigahertz. bandBand refers to a specified range of frequencies of electromagnetic radiation. is classified as a Bluetooth device. Bluetooth uses a frequency hopping protocol.
The percentage of the channel currently being used by cordless phones.
The percentage of the channel currently being used by Wi-FiWi-Fi is a technology that allows electronic devices to connect to a WLAN network, mainly using the 2.4 GHz and 5 GHz radio bands. Wi-Fi can apply to products that use any 802.11 standard. devices.
- —The graph display the channel quality corresponding to each of the WiFi and non-WiFi devices connected to the radios. When you hover over the bar graph, the following channel metrics are displayed:
Interfering Devices
Metrics |
Description |
Device type. This parameter can be any of the following:
ID number assigned to the device by the spectrum monitor. Spectrum monitors assign a unique spectrum ID per device type. |
Center frequency of the signal sent from the device. |
Channel bandwidth used by the device in KHz. |
Radio channels affected by the wireless device. |
Strength of the signal sent from the device measured in dBm. |
The device duty cycle. This value represents the percent of time the device broadcasts a signal. |
Time at which the device was first detected. |
Time at which the device status was updated. |
Click the icon to view details detected by the spectrum scanner. The page displays a table with following details of interfering devices:
The data displayed in the tab is refreshed every 15 seconds. Aruba Central (on-premises) displays the last recorded data for 30 minutes, if the device turns offline.
Actions
The drop-down list contains the following options:
- —Reboots the AP. For more information, see Rebooting an IAP.
- —Reboots the AP cluster. For more information, see Rebooting an IAP Cluster .
- —Enables the administrator to generate a tech support dump required for troubleshooting the AP. For more information, see Tech Support for an IAP .
Go Live
Aruba Central (on-premises) supports live monitoring of IAPs that support Aruba Instant 8.4.0.0 firmware version and above. Aruba Central (on-premises) allows you to monitor live data of an AP updated at every 5 seconds. For more information, see Enabling Live IAP Monitoring.
