Access Point > Overview > Performance
In the access point (AP) dashboard, the tab displays the size of data transmitted through the AP.
Viewing the Overview > Performance Tab
To navigate to the tab in the AP dashboard, complete the following steps:
In the app, set the filter to one of the options under , , or . For all devices, set the filter to . Ensure that the filter selected contains at least one active AP.
Under , click > .
A list of APs is displayed in the view.
Click an AP listed under .
The dashboard context for the AP is displayed.
In the AP dashboard context, click the tab. The tab is displayed.
To exit the AP dashboard, click the back arrow on the filter.
The tab provides the following details:
The graph indicates the size of data sent to and received by the device in bits per second for the wired or wireless networks. For example, Eth 0 or Eth 1 wired network profiles and specific SSIDsService Set Identifier. SSID is a name given to a WLAN and is used by the client to access a WLAN network. of wireless networks. You can also view data for all the wireless SSIDs by selecting from the drop-down list. You can view the overall data usage measured in bytes in the field.
The graph indicates the number of clients connected to the device for a selected time range in the time range filter. You can select a specific SSID or all SSIDs, Eth 0, or Eth 1 from the drop-down list provided in the section.
When you hover over the and graphs, it displays specific data for the selected timestamp.
Actions
The drop-down list contains the following options:
- —Reboots the AP. For more information, see Rebooting an IAP.
- —Reboots the AP cluster. For more information, see Rebooting an IAP Cluster .
- —Enables the administrator to generate a tech support dump required for troubleshooting the AP. For more information, see Tech Support for an IAP .
Go Live
Aruba Central (on-premises) supports live monitoring of IAPs that support Aruba Instant 8.4.0.0 firmware version and above. Aruba Central (on-premises) allows you to monitor live data of an AP updated at every 5 seconds. For more information, see Enabling Live IAP Monitoring.
