Access Point > Overview > AI Insights
In the access point (AP) dashboard, the tab displays information on AP performance issues such as excessive channel changes, excessive reboots, airtime utilization, and memory utilization.
Viewing Access Points > AI Insights
To navigate to the tab in the AP dashboard, complete the following steps:
In the app, set the filter to one of the options under , , or . For all devices, set the filter to . Ensure that the filter selected contains at least one active AP.
Under , click > .A list of APs is displayed in the view.
Click an AP listed under .
The dashboard context for the AP is displayed.
In the AP dashboard context, click the tab.
The page is displayed.
To exit the AP dashboard, click the back arrow on the filter.
AI Insights are displayed for the time range selected. Select the time range from the (
) to filter reports.
AI Insights Categories
are categorized in high, medium, and low priorities depending on the number of occurrences.
Red—High priority -
Orange—Medium priority -
Yellow—Low priority
AI Insights listed in the dashboard are sorted from high priority to low priority. The dashboard displays a report of network events that could possibly affect the quality of the overall network performance. Each insight report provides specific details on the occurrences of these events for ease in debugging. For more information, see The AI Insights Dashboard
The page displays the following insights:
- Clients with High Wi-Fi Security Key-Exchange Failures
- Clients with High 802.1X Authentication Failures
- Clients with DHCP Server Connection Problems
- Clients with High Number of MAC Authentication Failures
- Clients with High Number of Wi-Fi Association Failures
- Clients with Captive Portal Authentication Problems
