Monitoring Controllers in List View
The page provides information associated with the controllers provisioned and managed in Aruba Central (on-premises).
To navigate to the page, complete the following steps:
In the app, set the filter to one of the options under , , or . For all devices, set the filter to . Ensure that the filter selected contains at least one active controller.
Under , click > .
By default, the tab is displayed.
- Click the tab.
The page displays the following information:
- —Displays the total number of controllers. When you click the tab, it provides information about all the controllers in the table.
- —Displays the total number of online controllers. When you click the tab, it provides information about the online controllers in the table.
- —Displays the total number of offline controllers. When you click the tab, it provides information about the offline controllers in the table.
Controllers Table
The table displays the following information:
- —The name of the controller.
—Indicates that the controller is online.
—Indicates that the controller is offline. - —The name of the Mobility Conductor.
- —The name of the cluster.
- —The table displays the following information related to the AP:
- —Total number of APs.
- —Total number of offline APs.
- —Total number of online APs.
- —Total number of standby APs.
- —The number of clients connected to the controller.
- —The model number of the controller.
- —The status of the controller.
- —The IP address of the controller.
- —The MACMedia Access Control. A MAC address is a unique identifier assigned to network interfaces for communications on a network. address of the controller.
- —The serial number of the controller.
- —The group to which the controller belongs.
- —The labels associated with the controller. If multiple labels are associated with the controller, hover over the label link to view all the labels.
- —The site to which the controller belongs.
- —The version of the controller.
A search filter is provided only for the , , , , , , , , and columns. By default, the Controllers table sorts the offline devices and then the online devices.
Click the
icon to customize the view of Controllers table with additional columns. Click the button provided in the drop-down list to reset the Controllers table with default columns
only. To autofit the columns, select .
To download the file of the Controllers table, click the
icon.
