Aruba Central Online Help
Viewing the Controllers Tab
To view the Controller dashboard, complete the following steps:
- In the app, set the filter to .
- Click .
Controllers Dashboard
The dashboard page displays a complete list of offline or online controllers provisioned in Aruba Central. You can also use the following filtering options to view a specific set of controllers.
- —Displays a complete list of controllers. For more information, see Monitoring Controllers in List View.
- —Displays controller clusters deployed in Aruba Central. A controller cluster includes multiple controllers working together as a single managed entity. Controller clusters enable seamless roaming of clients between AP and ensure service continuity in the event of a failover. Controller clustering is supported only on devices running ArubaOS 8.x or later software versions. To view the cluster components, expand the cluster in the column. For more information, see Monitoring Clusters in List View.
- —Displays a list of controllers that are functioning as Mobility Conductors. The Aruba Mobility Conductor is an advanced controller deployed as a virtual machine (VMVirtual Machine. A VM is an emulation of a computer system. VMs are based on computer architectures and provide functionality of a physical computer.) or installed on an x86-based hardware appliance. A single Mobility Conductor or a cluster of Mobility Conductors oversees co-located controllers. It also displays the details about the APs associated with each controller. For more information, see Monitoring Mobility Conductors in List View.
