Aruba Central Online Help
You are here: Home > Aruba Central APIs > Obtaining Token Using OAuth Grant Mechanism
The following section describes the steps for obtaining the access token and refresh token using the authorization code grant mechanism:
APIApplication Programming Interface. Refers to a set of functions, procedures, protocols, and tools that enable users to build application software. calls are limited to 1 API per second. This rate-limit is applicable only to the APIs in the first 3 steps mentioned below.
Step 1: Authenticate a User and Create a User Session
The following API authenticates a user and returns a user session value that can be used to create future requests for a client with the specified username and password. It is assumed that you already have a client ID for your application. For more information on how to create an application and obtain tokens, see Creating Application and Token.
If user authentication is successful, the request will return HTTPHypertext Transfer Protocol. The HTTP is an application protocol to transfer data over the web. The HTTP protocol defines how messages are formatted and transmitted, and the actions that the w servers and browsers should take in response to various commands. code 200 and the response header will include the following attributes.
Table 1: Authentication and User session Response Codes
Header Key
Values
Description
https://apigw-<FQDN of the Aruba Central instance>/oauth2/authorize/central/api/login?client_id=<client_id>
csrftoken=xxxx; session=xxxx
The server returns a CSRF token and identifies the user session, which must be used for all subsequent HTTP requests.
Example
Request Method: POSTThe HTTP POST method is used for transferring data from a client (browser) to a server using the HTTP protocol. The POST method is considered a secure way of transferring data from a client as it carries the request parameter in the message body and does not append it in the URL string.
URL: https://apigw-<FQDN of the Aruba Central instance>/oauth2/authorize/central/api/login?client_id=<client_id>
Host: apigw.central.arubanetworks.com
Request Header:
Accept: application/json
Content -Type: application/json
POST Request Body(JSON):
{ "username": "xxxxx", "password": "xxxxx" }
Error Response:
400: Bad Request
Response Body (JSON):
{ "extra": {}, "message": "<error string>" }
401: Auth failure
{ "message": "Auth failure", "status": false }
429: API rate limit exceeded
{ "message": "API rate limit exceeded" }
Success Response:
200: OK
{ "status": true }
Response Header:
Set-Cookie: csrftoken=xxxx;session=xxxx;
The csrf token value received in the successful response message must be used as a parameter for all subsequent POST/PUT requests. The session value must also be used for all subsequent requests to maintain the user session context.
Step 2: [Optional] Generating Client Credentials
To generate client credentials, use the following URIUniform Resource Identifier. URI identifies the name and the location of a resource in a uniform format. and the request method:
Example
URI—https://apigw-<FQDN of the Aruba Central instance>/central/api/client_credentials?client_id=<client_id>
{ "customer_id": "<tenant_id>" }
Request Header: (Values from login API request)
Response Body(JSON):
{ "client_id": "<new-client-id>", "client_secret": <new-client-secret>" }
Step 3: Generate Authorization Code
After the user is authenticated and you have a valid session for that user, use this API to get authorization code. The authorization code is valid only for 5 minutes and must be exchanged for a token within that time.
Table 2: URL for to Generate an Authorization Code
URL
Description
The endpoint is a POST call to get an authorization code.
Query parameters for this API are as follows:
Table 3: Query Parameters for the Auth Code API
Parameter
Values
Description
client_id
client_id is a unique hexadecimal string
The client_id is a unique identifier that identifies the caller. Application developers obtain a client ID and a client secret when they register with the API gateway admin.
response_type
code
Use code as the response type to get the authorization code that can be exchanged for token
scope
all or read
Requested API permissions may be either all (for both read and write access) or read for read-only access.
Example
URL: https://apigw-<FQDN of the Aruba Central instance>/oauth2/authorize/central/api/?client_id=<client_id>&response_type=code&scope=all HTTP/1.1
Request Header:
Accept: application/json Cookie: “session=xxxx” X-CSRF-Token: xxxx
{ "customer_id": "xxxxx" }
Error Response:
400: Bad Request
401: Auth failure
Success Response:
200: OK
{ " auth_code ": “xxxx” }
Pass the csrf-token value you obtained in step one in the request header, otherwise the request will be rejected. Note the auth_code value in the response, as you will use this code to obtain an OAuthOpen Standard for Authorization. OAuth is a token-based authorization standard that allows websites or third-party applications to access user information, without exposing the user credentials. token.
Response Header:
Step 4: Exchange Auth Code for a Token
Once you have an authorization code, you just use that code to request an access from the server. The exchanges should be done within 300 seconds of obtaining the auth code from the previous step, or the API will return an error.
Table 4: URL for to Generate an Auth Token
URL
Description
https://apigw-<FQDN of the Aruba Central instance>/oauth2/token
The endpoint is a POST call to get an access token using the authorization code obtained from the server.
Table 5: Query Parameters for the Auth Code API
Parameter
Values
Description
client_id
client_secret
client_secret is a unique hexadecimal string
The client_secret is a unique identifier provided to each developer at the time of registration. Application developers can obtain a client ID and client secret when they register with the API gateway admin.
grant_type
authorization_ code
Use code to get the authorization code that can be exchanged for the token.
code
auth_code received from step 1
The authorization code received from the authorization server.
redirect_uri
string
The redirect URI must be the same as the one given at the time of registration. This is an optional parameter.
The response to this API query is a JSONJavaScript Object Notation. JSON is an open-standard, language-independent, lightweight data-interchange format used to transmit data objects consisting of attribute–value pairs. JSON uses a "self-describing" text format that is easy for humans to read and write, and that can be used as a data format by any programming language. dictionary with following values:
Table 6: Auth Token Values
Parameter
Values
Description
token_type
bearer
Identifies the token type. Central supports only the bearer token type (See https://tools.ietf.org/html/rfc6750)
refresh_token
string
Refresh tokens are credentials used to renew or refresh the access_token when it expires without repeating the complete authentication flow. A refresh token is a string representing the authorization granted to the client by the resource owner.
expires_in
seconds
The lifetime, in seconds, of the access token.
access_token
string
Access tokens are credentials used to access protected resources. An access token is a string representing an authorization issued to the client.
Example
URL: https: //apigw-<FQDN of the Aruba Central instance>/oauth2/token?client_id=<Ccentral-API-app-clientid>&client_secret=xxxx&grant_type=authorization_code&code=xxxx \
Response:
{ "refresh_token": "xxxx", "token_type": "bearer", "access_token": "xxxx", "expires_in": 7200 }
Step 5: Refreshing a Token
You can use the refresh token obtained in the previous step to update the access token without repeating the entire authentication process. A refresh token is only required once your access token is expired. You can only refresh a token for a new access token every 15 minutes. For example, when you refresh a new token, you can use the provided access token for 2 hours. If you want a new access token, you have to again refresh the token after 15 minutes from its last refresh.
Table 7: URL to Refresh a Token
URL
Description
The endpoint is a POST call to refresh the access token using the refresh token obtained from the server
Table 8: Query Parameters for Refresh Tokens
Parameter
Value
Description
client_id
client_secret
The client_secret is a unique identifier provided to each developer at the time of registration. Application developers obtain a client ID and a client secret when they register with the API gateway admin.
grant_type
refresh_token
Specify refresh_token as the grant type to request that an authorization code be exchanged for a token
refresh_token
string
A string representing the authorization granted to the client by the resource owner.
The response to this API query is a JSON dictionary with following values:
Parameter
Value
Description
token_type
bearer
Identifies the token type. Only the bearer token type is supported. For more information, see https://tools.ietf.org/html/rfc6750.
refresh_token
string
Refresh tokens are credentials used to renew or refresh the access token when it expires without going through the complete authorization flow. A refresh token is a string representing the authorization granted to the client by the resource owner.
expires_in
seconds
The expiration duration of the access tokens in seconds.
access_token
string
Access tokens are credentials used to access the protected resources. An access token is a string representing an authorization issued to the client.
Example
Method: POST
Response
Step 6: Deleting a Token
To delete the access token, access the following URLUniform Resource Locator. URL is a global address used for locating web resources on the Internet.:
Table 9: URL to Delete a Token
URL
Description
This endpoint is accessible over SSLSecure Sockets Layer. SSL is a computer networking protocol for securing connections between network application clients and servers over the Internet.. The HTTP (non-SSL) connections are redirected to SSL port. Customer ID is a string.
Example
Method : DELETE
URL:https://apigw-<FQDN of the Aruba Central instance>/oauth2/api/tokens
JSON Body:
{ "access_token": "<access_token_to_be_deleted>", "customer_id": "<customer_id_to_whom_token_belongs_to>" }
Headers:
Content-Type: application/json
X-CSRF-Token: <CSRF_token_obatained_from_login_API>
Cookie: "session=<session_obatained_from_login_API>"
