Aruba Central Online Help
Creating Application and Token
To create an application, complete the following steps:
- In the page, under , click .
The page is displayed.
- Click the tab.
The admin user will be able to create new apps for all the non-admin user by clicking in the tab.
- Click .
Figure 1 API Gateway Dashboard
- In the pop-up window, do the following:
- Enter the application name. In non-admin user profile, the field contains the logged-in user name and is non-editable.
- In the field, enter the redirect URLUniform Resource Locator. URL is a global address used for locating web resources on the Internet..
- From the Application drop-down list, select the application.
- Click . A new application is created and added to the table.
The table displays the following details:- —Name of the application. In non-admin user profile, the field contains the logged-in user name and is non-editable. Any new tokens generated in non- admin user profile is associated with the same application name.
- —Unique ID for each application.
- —Unique secret ID for each application.
- —Redirect URL.
- —Name of the application. For example, Network Operations.
- —Token created for the application. The option is available to admin user profile only.
- —Date on which the application was created.
- To delete the added application, click delete
icon on the row corresponding to an application and click to delete that application.
Only admin users will be able to generate tokens with multiple application names. In non-admin user profile, thefield contains the user name and is non-editable. Any new tokens generated in non- admin user profile is associated with the same application name. However, all the multiple application names and the associated tokens in non-admin user profiles from the earlier versions is retained in the table.
