All Clients
The page provides a summary view of all the clients connected to the network. You can filter clients based on the network the clients are connected to. The page displays key client information and also allows you to view a specific client detail page.
By default, the page displays a unified list of clients for the selected group. The list of clients is populated for a time range of 3 hours. To view the list of clients for a different time range, click the link and select the required time period. Total data usage for the selected time period is displayed above the client summary bar.
To filter clients based on the device to which the clients are connected, select the device type from the drop-down list:
- —Displays a unified list of clients connected to the network.
- —Displays a list of clients connected to the Instant AP.
- —Displays a list of clients connected to the switch.
- —Displays a list of clients connected to the Aruba Controller.
The wired client will show up in the page only if the client is connected to an Aruba 2540 Series, Aruba 2920 Series, Aruba 2930F Series, Aruba 2930M Series, Aruba 3810 Series, or Aruba 5400R Series switch.
To filter clients based on the network to which the clients are connected, click the network type from the bar:
- —Displays a list of clients connected to the wireless network. The wireless clients are denoted by the
icon. - —Displays a list of clients connected to the wired network. The wired clients are denoted by the
icon. - Remote—Displays a list of clients connected through VPNVirtual Private Network. VPN enables secure access to a corporate network when located remotely. It enables a computer to send and receive data across shared or public networks as if it were directly connected to the private network, while benefiting from the functionality, security, and management policies of the private network. This is done by establishing a virtual point-to-point connection through the use of dedicated connections, encryption, or a combination of the two.. The remote clients are denoted by the
icon.
The table lists the details of each client. By default, All clients is selected and the table displays the following columns: , , , , , , , , and . Click the ellipsis icon to perform additional operations:
- —Downloads the client details in the .csv file format.
- —Selects all columns.
- —Resets the table view to the default columns.
If a filter icon appears next to the column header, click it and enter the filter criteria or select a filter criteria from the Client Summary bar. For example, to search a client, click the predefined filter criteria: Connecting, , , , or from the Client Summary bar and in the column enter the name of the client.
Column |
Applicability |
Description |
Username, hostname, or MACMedia Access Control. A MAC address is a unique identifier assigned to network interfaces for communications on a network. address of the client. Click the client name to view the client details page. |
Client connection status. Use the filter option to view the following:
Hover your mouse over the status to view:
IP address of the client. |
VLANVirtual Local Area Network. In computer networking, a single Layer 2 network may be partitioned to create multiple distinct broadcast domains, which are mutually isolated so that packets can only pass between them through one or more routers; such a domain is referred to as a Virtual Local Area Network, Virtual LAN, or VLAN. of the device to which the client is connected. |
All |
AP name, Switch name, or Controller name. This is the first layer 2 hop for the client. If the device does not have a name, the MAC address is displayed. |
Displays the SSIDService Set Identifier. SSID is a name given to a WLAN and is used by the client to access a WLAN network. for wireless clients and the port number for wired clients. The column title displays SSID and Port interchangeably based on the device filters. For APs, the column title displays SSID. For switch and controller, the column title displays as Port. |
AP |
Role assigned by the Instant AP. |
Controller |
Role assigned by the Aruba Controller. |
AP |
Client health. The value can be one of the following:
AP |
Stage of the connection where the client failed to connect. The failure reasons could be:
Group name of the device managed by Aruba Central. |
Name of the site in which the devices managed by Aruba Central are installed. |
MAC address of the client. |
Host name of the client. |
Username of the client. |
AP |
Security mode used by the client. |
Authentication type used by the client to connect with the device. |
Global Unicast IPv6 Address |
When the IPv6 address is present for a client, you can view its Global Unicast IPv6 address. Click the ellipsis and select the column to view the value if the column is not displayed. |
Link Local IPv6 Address |
When the IPv6 address is present for a client, you can view its Link Local IPv6 address. Click the ellipsis and select the column to view the value if the column is not displayed. |
AP |
Total data usage for the selected time period. |
Operating system of the client. |
Date and time at which the client was last seen. |
Date and time since when the client was connected. |
AP |
Name of the Instant AP. |
AP |
MAC address of the Instant AP. |
AP |
Last connected channel and bandBand refers to a specified range of frequencies of electromagnetic radiation.. |
Name of the switch. |
Port number of the switch. |
Name of the Aruba Controller. |
Tunneled |
Tunnel mode applicable for the Aruba Gateway managed WLANWireless Local Area Network. WLAN is a 802.11 standards-based LAN that the users access through a wireless connection., UBT, or PBT client. |
Segmentation |
Type of segmentation. The type of segmentation can be:
To view the details about dynamic segmentation, a gateway must be licensed in Aruba Central and connected to the switch. |
