What's New
The following features and enhancements are now available in Aruba Central (on-premises):
Aruba Central (on-premises) allows you to monitor clients in the dashboard. Following are the client monitoring enhancements:
The Blink LEDLight Emitting Diode. LED is a semiconductor light source that emits light when an electric current passes through it. option on Client Details page enables the blinking of LEDs on APs to identify the location of the APs.
Navigate to the > page, and click the client name to view the Client Details page. The Connection section under Client Details page displays the Blink LED option. Click Blink LED to enable the blinking of LEDs on the AP.
For more information, see Wireless Client Details.
The Overview > Summary page of the wireless client dashboard now contains an Association History table. This table lists a series of association or disassociation events for the wireless client registered over a period of time for campus APsCampus APs are used in private networks where APs connect over private links (LAN, WLAN, WAN or MPLS) and terminate directly on controllers. Campus APs are deployed as part of the indoor campus solution in enterprise office buildings, warehouses, hospitals, universities, and so on.. Some examples of events displayed include roaming information, AP, SSIDService Set Identifier. SSID is a name given to a WLAN and is used by the client to access a WLAN network., BandBand refers to a specified range of frequencies of electromagnetic radiation. changes and so on. For more information about the Association History table, see Wireless Client Details.
Aruba Central (on-premises) supports live monitoring of the client. Click to start live monitoring of the client and click to stop live monitoring of the client. Live monitoring is supported only if the AP is running Aruba Instant 8.4.0.0 firmware version. Live monitoring stops after 15 minutes. At any point, you can click to go back to the historical view. For more information, see Wireless Client Details.
Aruba Central (on-premises) allows you to troubleshoot issues related to a client or a site in real time for detailed analysis. Live troubleshooting is supported only if the wireless client is connected to the access point running Aruba Instant 8.4.0.0 or a later version. Live events are supported only on Instant APs. The live troubleshooting can only be performed at a site level or for a specific client. For more information, see Client Live Troubleshooting.
The refresh icon in the Wireless Client Health Bar refreshes the data on the Health Bar for the wireless client. The refresh icon in the Wired Client Health Bar refreshes the data on the Health Bar for the wired client. This icon appears only after 15 minutes of pinning the Health Bar to the Client Details page and until 15 minutes it is considered as the Live Health Bar because the data is updated every 5 seconds. The Live Health Bar is a 15-minute session that is initiated when you hover over the wireless client name in the Client Details page under Manage > Clients in the Network operations app. A pop-up appears displaying latest values that are updated every 5 seconds for the Connection status, Device Health, Signal Quality, Tx | Rx Rate, and Connected To parameters. After the 15-minute session of the Live Health Bar, the refresh icon appears. You may click the refresh icon to restart the session. You can also pin this window to the Client Details page. For more information, see:
A new client type called Remote is introduced for clients that are connected through a VPNVirtual Private Network. VPN enables secure access to a corporate network when located remotely. It enables a computer to send and receive data across shared or public networks as if it were directly connected to the private network, while benefiting from the functionality, security, and management policies of the private network. This is done by establishing a virtual point-to-point connection through the use of dedicated connections, encryption, or a combination of the two.. You can view the details about the remote client type in the following pages:
- Summary—The Remote Clients count is added to the Clients graph in the Summary tab at the Global context. For more information, see Global—Summary.
- Client Details:
- List view—The Remote column is added to the Client Summary bar and the value indicates the number of remote clients present in the network.
- Summary view—The Remote column is added to indicate the number of remote clients connected to the network and Remote Bandwidth Usage is added in the Usage tab.
- Remote client dashboard—Clicking on the remote client in the Client Details page navigates to the context dashboard. It consists of the Health Bar , Summary, Applications, Security, and Tools tabs. For more information, see Remote Client Details.
Following are the Controller monitoring enhancements:
- In the Controller dashboard, the and the tabs indicate the total number of online and offline devices.
- —A new column is introduced in the and the table that displays the model number of the device.
- By default, the and the table sorts the offline devices and then the online devices.
For more information, see Viewing the Controllers Tab.
- —Aruba Central (on-premises) does not support rebooting of the controller.
Following are the AP monitoring enhancements:
The Blink LED option on AP Details page enables the blinking of LEDs on APs to identify the location of the APs.
Navigate to the Access Points configuration dashboard, and click an AP listed under Device Name. The Device section under Overview > Summary page displays the Blink LED option. Click Blink LED to enable the blinking of LEDs on the AP.
For more information, see Access Point > Overview > Summary.
The Channel Utilization graph indicates the percentage of channel utilization for the selected time range from the time range filter, and includes the following categories:
- Transmitting
- Receiving
- Non-Wifi Interference
- Total Utilization
Navigate to the Access Points configuration dashboard, and click an AP listed under Device Name. In the AP dashboard context, click the RFRadio Frequency. RF refers to the electromagnetic wave frequencies within a range of 3 kHz to 300 GHz, including the frequencies used for communications or Radar signals. tab to view the Channel Utilization graph.
For more information, see Channel Utilization.
Navigate to the Access Points overview dashboard, and click an AP listed under Device Name. The WLANSWireless Local Area Network. WLAN is a 802.11 standards-based LAN that the users access through a wireless connection. section in the AP Details page displays the list of all SSIDs configured for the AP. When you expand a SSID in the table, you can view the additional information for , , and radios.
Navigate to the Access Points overview dashboard, and click an AP listed under Device Name. In the Health Status graph of the AP Details page, the text indicates the poor health limit of the device in the network.
Aruba Central (on-premises) now supports an access point (AP) replacement workflow. Navigate to the Access Points overview dashboard, and then click an AP listed under Device Name. The option under allows you to replace an offline AP in the Aruba Central (on-premises) web UI.
For more information, see Replacing an AP.
Aruba AirSlice, based on IEEEInstitute of Electrical and Electronics Engineers. 802.11ax standard, is similar to 5G network slicing architecture which allows network operators to build virtual networks tailored for specific application requirements. AirSlice allows network operators to monitor applications used by clients. AirSlice supports multiple services such as gaming, IoTInternet of Things. IoT refers to the internetworking of devices that are embedded with electronics, software, sensors, and network connectivity features allowing data exchange over the Internet., voice, video, and so on. AirSlice is available for all clients; however, 802.11ax clients have enhanced benefits due to efficient uplink and downlink traffic scheduling mechanism.
Aruba Central (on-premises) supports live monitoring of Instant APs that support Aruba Instant 8.4.0.0 firmware version and above. It allows you to monitor live data of an AP updated at every 5 seconds.
Navigate to the Access Points overview dashboard, and click an AP listed under Device Name. Click the button to start live monitoring of the AP and click the button to exit live monitoring of the AP.
For more information, see Enabling Live IAP Monitoring.
Aruba Central (on-premises) allows you to troubleshoot issues related to access points. The AP Live events feature is similar to client live troubleshooting, but in this case, we can enable live events at the AP level. Currently, users can subscribe to Radio, VPN, and Spectrum events. For more information, see AP Live Events.
Changing AOS-Switches firmware from latest version to earlier major versions is not recommended if the switches are managed in UI groups. For features that are not supported or not managed in Aruba Central on earlier AOS-Switch versions, changing firmware to earlier major versions might result in loss of configuration.
Following are the AOS-Switch configuration enhancements:
- —Administrators can now configure SNMPv3Simple Network Management Protocol version 3. SNMPv3 is an enhanced version of SNMP that includes security and remote configuration features. on AOS-Switches. SNMPv3 uses authentication and privacy protocols to provide enhanced security.
For more information, see Configuring SNMPv3 on AOS-Switches.
- —Administrators can now configure user-based tunnel on switches from the page. This allows the switch to tunnel traffic to an Aruba controller on a user-role basis or device basis.
For more information, see Configuring Tunnel Node Server on AOS-Switches.
- —Administrators can now configure authentication order and priority for the authentication methods. This allows switch to authenticate the client requests sequentially.
For more information, see Configuring Authentication Order and Priority.
- —Administrators can now configure ClearPassClearPass is an access management system for creating and enforcing policies across a network to all devices and applications. The ClearPass integrated platform includes applications such as Policy Manager, Guest, Onboard, OnGuard, Insight, Profile, QuickConnect, and so on. Server from the page. This allows you to enable the switch to download the user-roles from the ClearPass server.
For more information, see Configuring RADIUS Server Settings on AOS-Switches.
- —Administrators can now enable Downloadable User Role and configure ClearPass settings to download user-roles, policy, and class from the ClearPass Policy ManagerClearPass Policy Manager is a baseline platform for policy management, AAA, profiling, network access control, and reporting. With ClearPass Policy Manager, the network administrators can configure and manage secure network access that accommodates requirements across multiple locations and multivendor networks, regardless of device ownership and connection method. server.
For more information, see Configuring Downloadable User Role on AOS-Switches.
- — configuration is moved from the tab to the tab.
For more information, see Configuring Routing on AOS-Switches.
- — configuration is renamed to and moved from the tab to the tab.
For more information see Configuring DHCP on AOS-Switches.
Aruba Central does not support adding pre-configured switches to a UI group. Pre-configured switches that have pre-assigned UI switch groups are added to the Unassigned Devices group. To provision a pre-configured switch to a UI group or move a switch from a template group to a UI group, complete the following steps:
- Clear the switch configuration.
- Delete the device from Aruba Central.
- Provision the switch as a new device in a UI group.
For more information, see Configuring AOS-Switches in UI Groups.
- —Administrators can now configure SNMPv3 on AOS-Switches. SNMPv3 uses authentication and privacy protocols to provide enhanced security.
- —Administrators can now configure ClearPass Server from the page. This allows you to enable the switch to download the user-roles from the ClearPass server.
- —Administrators can now enable Downloadable User Role and configure ClearPass settings to download user-roles, policy, and class from the ClearPass Policy Manager server.
Following are the configuration audit enhancements:
Configuration Audit now displays local overrides and configuration differences in an improved UI. It displays the overrides in groups based on the configuration module where the difference exists. For example, any overrides in VLANVirtual Local Area Network. In computer networking, a single Layer 2 network may be partitioned to create multiple distinct broadcast domains, which are mutually isolated so that packets can only pass between them through one or more routers; such a domain is referred to as a Virtual Local Area Network, Virtual LAN, or VLAN. configuration is displayed under the drop-down.
- option has been renamed to .
For more information, see Verifying Device Configuration Status.
Aruba Central (on-premises) is a deployment of Aruba Central in your datacenter. Aruba now supports single node deployment for users with a deployment size of any of the following:
- 1000 APs where APs can be either Instant APs, Campus APs, or APs along with the controllers that manage APs; or a mix of any of these devices.
- 500 switches where switches can be AOS-S switches or CX switches or a mix of the two.
- In a mixed mode of switches and APs, up to 800 APs and 200 switches are supported.
It also supports backing up and restoring system data from a single node deployment to three node deployment and above.
For more information, see Single Node Support
This release introduces the following enhancements to the dashboard:
- The option now includes a toggle switch that allows you to enable or disable the set firmware compliance.
- Upgrading all devices now include the Site level support. You can now upgrade all the devices using the option for a specific site or multiple sites. To upgrade all devices, in the global context, click option and select the sites from the drop-down list.
- The firmware devices tab now includes a column that displays the site at which the devices are associated.
For more information, see Upgrading Device Firmware.
This release introduces the Upgrade Watcher notification system that allows you to upgrade to the latest major available version. On user account login, the watcher checks for any version release and notifies you to upgrade within the set date. To know more about Upgrade Watcher, see Upgrade Watcher.
This release introduces the tab in the dashboard. Streaming APIApplication Programming Interface. Refers to a set of functions, procedures, protocols, and tools that enable users to build application software. allows customers to subscribe to select set of services instead of polling the NB API to get an aggregated state or statistics of the events. Streaming API supports the following services:
- Audit
- AppRF
- Monitoring
- Location
- Security
For more information, refer to API Reference Guide.
This release introduces the following enhancements to the feature:
If you unassign licenses from IAPs, they are now removed from the Floorplans and the deployed device-list. If you re-assign licenses to the IAPs, they are added back to the same Floorplan location and deployed device-list. Also, if the license gets auto-expired, the affected devices are removed. On license renewal, the affected devices are added back.
The navigation to the dashboard from an AP is now improved. You can navigate to the floorplan for a specific site by using the floorplan available at the AP dashboard.
To view the Floorplans page from an AP details page, complete the following steps:
- In the app, set the filter to .
The global dashboard is displayed. - Under , click .
A list of APs is displayed in the List view. - Click the name to view the page
If there are many APs connected to the network, click or to filter the online or offline APs. - Optionally, enter the AP name in the Device Name column and then click the AP.
The page is displayed. - Under , click .
The floor plan details for the highlighted AP is displayed. - Click anywhere on the floor plan to navigate to the floor plan for a site with the AP highlighted.
The floor plan details for the AP is only accessible for the devices that are assigned with license.
For more information, see About Floorplans.
Aruba Central (on-premises) now allows you to perform offline migration of the Device Inventory data and Visual RF data from AirWave to Aruba Central (on-premises) in the Global Settings > System Management > Migration tab of the Account Home page. You can now perform offline migration by uploading the backup file that was earlier downloaded from AirWave. The user need not have the AirWave 8.2.6.1 server up and running for an offline migration.
Offline migration is required when the user wants to deploy Aruba Central (on-premises) on the same AirWave server.
For more information see the Aruba Central (on-premises) Migration Guide.
Aruba Central (on-premises) UI now allows you to view and edit configurations of multiple AOS-CX switches in the MultiEdit mode of the AOS-CX switch configuration page. This mode supports editing the configuration of a maximum of 50 switches. For more information see the Aruba Central (on-premises) User Guide.
The Aruba Central built-in AI Insights feature proactively identifies and solves network issues. The following enhancements are introduced in the AI Insights page:
Apart from the four insights that already exist, this release introduces two more insights:
Clients had a high number of Wi-FiWi-Fi is a technology that allows electronic devices to connect to a WLAN network, mainly using the 2.4 GHz and 5 GHz radio bands. Wi-Fi can apply to products that use any 802.11 standard. Association failures
Clients had problems authenticating with the Captive PortalA captive portal is a web page that allows the users to authenticate and sign in before connecting to a public-access network. Captive portals are typically used by business centers, airports, hotel lobbies, coffee shops, and other venues that offer free Wi-Fi hotspots for the guest users.
- The pie chart data available in the cards within each insight type can be now modified based on your requirement. To highlight specific entries in a card, click the checkbox next to each label.
The insight detail tables are more interactive. The filter
icon allows you to filter data in each table column. The
and
icons allow you to sort the columns in ascending and descending order. -
The Time Series Graph can now be modified. The entries in each time series bar can be customized to highlight a specific entry by clicking on it. Only one specific entry can be highlighted at a time.
For more information, see the following:
In the Network Operations app, use the filter to select a group, label, site, or a device and then, select Analyze > Tools to avail of different troubleshooting tools. The Tools menu option enables users to troubleshoot AP, controller, and switch issues in the network through various tests available within Network Check, Device Check, and Commands tabs. In this release, the troubleshooting tools have undergone the following enhancements:
- New Controller Connectivity Tests—Apart from Ping Test and Traceroute, users can now diagnose controller network issues with the following new tests:
Ping Sweep Test—Performs an advanced check on host reachability and network connectivity.
HTTPHypertext Transfer Protocol. The HTTP is an application protocol to transfer data over the web. The HTTP protocol defines how messages are formatted and transmitted, and the actions that the w servers and browsers should take in response to various commands. Test—Sends packets to the HTTP URLUniform Resource Locator. URL is a global address used for locating web resources on the Internet. and tries to establish a connection and exchange data.
HTTPSHypertext Transfer Protocol Secure. HTTPS is a variant of the HTTP that adds a layer of security on the data in transit through a secure socket layer or transport layer security protocol connection. Test—Sends packets to the HTTPS URL and tries to establish a connection and exchange data.
Speed Test (iPerf)—Performs a speed test to measure network speed and bandwidth. To perform a speed test, you must provide the iPerf server address, protocol type, and speed test options such as bandwidth.
- Additional Tests Parameters—Under the Network Check tab, Show Additional Test Settings is introduced to enhance the troubleshooting procedure with few additional parameters for the following tests:
Ping Test—Performs an advanced check on host reachability and network connectivity.
HTTP Test—Sends packets to the HTTP URL and tries to establish a connection and exchange data.
HTTPS Test—Sends packets to the HTTPS URL and tries to establish a connection and exchange data.
TCPTransmission Control Protocol. TCP is a communication protocol that defines the standards for establishing and maintaining network connection for applications to exchange data. Test—Sends packets to the host, for example, FTPFile Transfer Protocol. A standard network protocol used for transferring files between a client and server on a computer network. server, and tries to establish a connection and exchange data.
The Show Additional Test Settings is not displayed when a Test type is not selected. You can show or hide the Show Additional Test Settings section.
- Advanced device check aims to identify, diagnose, and debug issues on the device using the command-line interface. The Commands tab on the Tools page lists commands specific to a particular device for troubleshooting. The show client debug command is introduced for this purpose. For more information, see The CLI Bank.
For more information, see Using Troubleshooting Tools.
The following enhancements are introduced in the Alerts & Events page:
- Site-Specific Email Notifications for Alerts—Aruba Central (on-premises) enables you to add specific email addresses for each site. You can now configure site-specific email addresses, so that alert notifications for each site are sent to the respective site administrators. Since the email notifications are differentiated based on the site, it is possible for site administrators to only receive those alerts which are pertinent to their sites. You can add up to ten email addresses for each site.
To configure an email address for a site, select a site in Aruba Central (on-premises) and navigate to the page. When you configure email addresses in the site dashboard, the email settings for the site configured in the global dashboard are ignored.
For more information, see Configuring Site-specific Email Notifications. -
A new column, Elapsed Time is added in the Acknowledged Alerts table to show the timestamp difference between when a specific alert actually occurred and when that alert was acknowledged. For more information, see Viewing Alerts in List view.
- The Events table offers additional details regarding events related to IAPs. For more information, see Viewing Events List View.
- The following two new Central System alerts are added to notify customers regarding COP upgrade:
- COP Upgrade Schedule
- COP Upgrade Check Failed
For more information, see Central System Alerts.
- The following new Switch alerts are added:
Switch Uplink Port Usage—It generates an alert when the total uplink port usage of a switch at a site exceeds the configured value in gigabytes (GB) within a specified duration.
Switch NAE Status—It generates an alert when the NAE status for the AOS-CX switches exceed the Normal value.
For more information, see Switch Alerts.
- The following new AP alerts are added:
- Radio Non WiFi Utilization—It generates an alert when the AP radio non-Wi-Fi utilization exceeds the threshold value.
- AP Tunnel Down—It generates an alert when a single L3 tunnel is configured on the AP goes down.
- All AP Tunnels Down—It generates an alert when all the L3 tunnels configured on the AP goes down.
For more information, see Access Point Alerts.
This release introduces the following enhancements to the tab:
The tab now supports displaying the details about third party and Aruba-unmanaged devices available in your network. A new filter is introduced that enables you to show or hide the third party and Aruba-unmanaged devices in the topology map. An Aruba-unmanaged device is an Aruba or an HP device that is not managed by Aruba Central (on-premises).
- The tab now includes an pane that provides information about the orphan and the offline third-party devices. A third-party device is considered to be orphan when all its neighboring Aruba devices get deleted. A third-party device is considered to be offline when all its neighboring Aruba devices are offline.
- The tab now supports displaying the VLAN overlay details for AOS-Switch and AOS-CX switches.
For more information, see Monitoring Sites in the Topology Tab.
The following is the list of enhancements for the Reports module in Aruba Central (on-premises):
- report—Administrators can now configure a report to view the following data for one year:
- Trends such as , , , , , and .
- Top N Widgets such as , , , , , and . The and options are only available when you select in the context level. For , you can choose Top 5, Top 10, Top 25, and Top 50 widgets.
For more information, see Reports .
Multi-tier licensing is applicable to Unified Communications applications. For more information, see Unified Communications.
Following are the enhancements to the Central Search bar:
Aruba Central search shows cards with additional information specific to the search context. You can click on the search cards to navigate to that particular pages in the app. For more information on search cards, see Client Search Terms, Device Search Terms, and Site Search Terms pages.
Following are the new and deprecated APIs:
Following APIs are introduced in the category:
- /vlans/{site_id}
- /unreachableDevices/{site_id}
- /monitoring/v2/bssidsBasic Service Set Identifier. The BSSID identifies a particular BSS within an area. In infrastructure BSS networks, the BSSID is the MAC address of the AP. In independent BSS or ad hoc networks, the BSSID is generated randomly.
- /monitoring/v3/aps/bandwidth_usage
- /monitoring/v2/aps/bandwidth_usage/topn
Following APIs are deprecated:
- /monitoring/v1/bssids
- /monitoring/v1/aps/bandwidth_usage/topn
The Label parameter in the new APIs supports only label filter request and returns empty result on site filter request. However, for the deprecated APIs, both the site and label filter request is supported in the Label parameter.
- /monitoring/v2/networks
- /monitoring/v2/networks/{network_name}
- /monitoring/v2/networks/bandwidth_usage
- /monitoring/v1/networks
- /monitoring/v1/networks/{network_name}
- /monitoring/v1/networks/bandwidth_usage
- /platform/licensing/v1/subscriptions
- /platform/licensing/v1/subscriptions/stats
- /platform/licensing/v1/services/enabled
- /platform/licensing/v1/services/config
- /platform/licensing/v1/autolicensing/services/{service}/status
- /platform/licensing/v1/customer/settings/autolicense
- /platform/licensing/v1/msp/customer/settings/autolicense
- /platform/licensing/v1/subscriptions/assign
- /platform/licensing/v1/subscriptions/unassign
- /platform/licensing/v1/subscriptions/devices/all
- /platform/licensing/v1/msp/subscriptions/devices/all
Following APIs are deprecated in the category:
- /subscriptions
- /subscriptions/stats
- /services/enabled
- /subscriptions/assign
- /services/config
- /autolicensing/services/{service}/status
- /customer/settings/autolicense
- /msp/customer/settings/autolicense
- /subscriptions/unassign
- /subscriptions/devices/all
- /msp/subscriptions/devices/all
