Remote Client Details
The remote clients are clients that are connected to the network through VPNVirtual Private Network. VPN enables secure access to a corporate network when located remotely. It enables a computer to send and receive data across shared or public networks as if it were directly connected to the private network, while benefiting from the functionality, security, and management policies of the private network. This is done by establishing a virtual point-to-point connection through the use of dedicated connections, encryption, or a combination of the two.. The in-house wireless and wired clients can also be authenticated using the VPN (VIAVirtual Intranet Access. VIA provides secure remote network connectivity for Android, Apple iOS, Mac OS X, and Windows mobile devices and laptops. It automatically scans and selects the best secure connection to the corporate network.). The overview page displays the client summary details, applications, and events for the selected remote client.
This section includes the following topics:
Viewing Remote Clients Connected through VPN
To view the details of a remote client:
- In the app, set the filter to one of the options under , , or . For all devices, set the filter to . The dashboard context for the selected filter is displayed.
- Under , click . The page is displayed.
- By default, the table displays a unified list of clients for the selected group, label, site or device.
- Click the name of the remote client to open the corresponding page. If there are many clients connected to the network, click to filter the clients connected to the network.
- Enter the client name in the column, and click the client name. The client page is displayed.
- Click the required tab name to navigate and view the details.
Summary
The client summary page displays the following information.
Health Bar
Field |
Description |
Connection status icon |
Displays the icons with the connection status of the client. Connection status is updated immediately on state change. The available statuses are:
Displays the name of the AP that broadcasts the SSIDService Set Identifier. SSID is a name given to a WLAN and is used by the client to access a WLAN network. to which the client is connected. Click the name of the AP to view the device details page. |
Overview
The tab displays information about the type of data path that the client uses, the network and connectivity details, and basic client details such as IP address of the client, type of encryption etc. The following table describes the information displayed in each section:
Section |
Description |
Displays the data path of the client in the network. Click the controller to view the details page. The data path can be > > |
Displays the following information:
Displays the incoming and outgoing throughput traffic for the client during a specific time range. By default, the graph on the pane is plotted for a time range of 3 hours. To view the graph for a different time range, click the link. You can choose to view the graph for a time period of 3 hours, 1 day, 1 week, 1 month, or 3 months. |
AI Insights
The tab displays information about client performance and connectivity issues. AI Insights are displayed for a selected time period based on the time selected in . The user can select 3 hours, 1 week, 1 day, or 1 month to view the insight data. are categorized in high, medium, and low priorities depending on the number of occurrences.
Red—High priority -
Orange—Medium priority -
Yellow—Low priority
Each insight report specific details on the occurrences of these events for ease in debugging. For more information, see The AI Insights Dashboard
The client page displays the following insights:
- Clients with High Wi-Fi Security Key-Exchange Failures
- Clients with High 802.1X Authentication Failures
- Clients with DHCP Server Connection Problems
- Clients with High Number of MAC Authentication Failures
Applications
The page consists of the , and AirGroup tab.
Visibility
The dashboard provides a summary of client traffic and their data usage to and from applications, and websites. You can also analyze the client traffic flow using the graphs displayed in the dashboard. The tab consists of a list view and a graph view. The dashboard displays metrics and graphs related to client traffic flow in the following sections:
For more information about enabling , list of supported Instant APs, and the data displayed on the and sections, see Application Visibility.
Sessions
The client sessions page consists of the firewallFirewall is a network security system used for preventing unauthorized access to or from a private network. session details for the client connected to a Branch Gateway. The page displays information filtered by the IP address of the client. The pane displays the device the client is connected to, total number of sessions, and the time stamp of when the page was last refreshed. The sessions details page refreshes automatically, to refresh the page manually, click the refresh icon after the timestamp.
The table lists the details of each session. By default, the table displays the following columns: , , Protocol, , , DSCPDifferentiated Services Code Point. DSCP is a 6-bit packet header value used for traffic classification and priority assignment. , , , and .
Click the ellipsis icon to perform additional operations:
- —Adjusts the column width of the table to fit the page evenly.
- —Resets the table view to the default columns.
If a filter icon appears next to the column header, click it and enter the filter criteria or select a filter criteria. The following table describes the information displayed in each session:
Section |
Description |
Displays the list of applications. |
Displays the source IP address. |
Displays the destination IP address. |
Displays the communication protocol used. |
Displays the source port number. |
Displays the destination port number. |
DSCP |
Displays the DSCP value. |
Displays the active flags |
Displays the number of packets. |
Displays the total number of bytes. |
Displays the connection state of the application. The state can either be Denied, Active, or Inactive. |
Displays the application specific action. |
Displays the VLAN the client is connected to. |
Displays the start time. |
Displays the receive time. |
Displays the WebCC category. |
Displays the WebCC reputation. |
Displays the WebCC score. |
Displays the application category. |
Priority |
Displays the priority value. |
Events
In the page, the table displays the following columns by default: , , and . Click the ellipsis icon to perform additional operations:
If a filter icon appears next to the column header, click it and enter the filter criteria or select a filter criteria. The following table describes the information displayed in each event:
Section |
Description |
Displays the time at which the event occurred. |
Displays the type of the event. |
Displays the detailed description of the event. |
Displays the MAC address of the device. |
To download events into a CSVComma-Separated Values. A file format that stores tabular data in the plain text format separated by commas. format, click the download button. Aruba Central generates the CSV report of all the events for the selected client.
You can also filter the events based on the type of events, click the . Select the type of events from the list and click . The events under the selected categories get listed in the table.
