Wireless Client Details
The wireless client overview page displays the client summary details, applications, and events details for the selected client.
This section includes the following topics:
- Viewing Clients Connected to Wireless Networks
- Summary
- Overview
- Disconnecting a Wireless Client from an AP
- Blocking a Wireless Client from an AP
- Applications
- Events
To view the details of a client connected to the wireless network:
- In the app, use the filter bar to select a group or a device.
- Under , click . The clients overview page is displayed.
- Click the list icon to view the client table.
- By default, the table displays a unified list of clients for the selected group.
- Click the client name to view the client details page. If there are many clients connected to the network, click to filter the clients connected to the wireless network and enter the client name in the column and then click the client name. The page is displayed.
Summary
The client summary page displays the following information:
Wireless Client Health Bar
Field |
Description |
Connection status icon |
Displays the icons with the connection status of the client. Connection status is updated immediately on state change. The available statuses are:
Signal strength of the client device. The signal strength value is displayed in percentage: 0-30—Poor 31-70—Fair >71—Good |
SNRSignal-to-Noise Ratio. SNR is used for comparing the level of a desired signal with the level of background noise. for the client as measured by the AP. The SNR value is displayed in decibels: 0-20—Poor 21-35—Fair >35—Good |
Data transmission or reception rate. |
Name of the AP that broadcasts the SSIDService Set Identifier. SSID is a name given to a WLAN and is used by the client to access a WLAN network. to which the client is connected. Click the name of the AP to view the device details page. |
Refresh icon |
Restarts the Live Health Bar session. This icon appears only after 15 minutes of pinning the Health Bar to the Client Details page and it is called as the Live Health Bar because the data is updated every 5 seconds. For more information, see Live Health Bar. |
Overview
The tab displays information about the type of data path that the client uses, the network and connectivity details, and basic client details such as IP address of the client, type of encryption etc. The following table describes the information displayed in each section:
Section |
Description |
Displays the data path of the client in the network. Click the AP icon to view the AP details page. The data path can be one of the following:
Displays the following information:
Displays the incoming and outgoing throughput traffic for the client during a specific time range. By default, the graph on the pane is plotted for a time range of 3 hours. To view the graph for a different time range, click the link. You can choose to view the graph for a time period of 3 hours, 1 day, 1 week, 1 month, or 3 months. |
Displays the health score and status of a wireless client. By default, the graph on the pane is plotted for a time range of 3 hours. To view the graph for a different time range, click the link. You can choose to view the graph for a time period of 3 hours, 1 day, 1 week, 1 month, or 3 months. The graph is plotted against the client health and client score, where the client health is measured as , , or and the health score ranges between 0 to 100.
Displays the signal quality and the SNR for the wireless client as measured by the AP. The SNR value is displayed in decibels: 0-20—Poor 21-35—Fair >35—Good |
Displays the percentage of Tx and Rx retries by a wireless client. |
Displays the data transmission and reception rate for the wireless client . |
Association History
The Association History table is available only for Campus APsCampus APs are used in private networks where APs connect over private links (LAN, WLAN, WAN or MPLS) and terminate directly on controllers. Campus APs are deployed as part of the indoor campus solution in enterprise office buildings, warehouses, hospitals, universities, and so on.. It consists of a list of events for client association or dissociation such as when it disconnects from an AP, roams between APs, changes SSID, or change in the radio or BSSIDBasic Service Set Identifier. The BSSID identifies a particular BSS within an area. In infrastructure BSS networks, the BSSID is the MAC address of the AP. In independent BSS or ad hoc networks, the BSSID is generated randomly.. The table launches only the default parameters, click the Ellipsis icon and select all columns to view all the parameters. By default, the data is displayed for a time range of 3 hours. To change the time range, click the Time Range Filter link and select the required option as 3 hours, 1 day, 1 week, 1 month, or 3 months. Additionally, you can use the filter option in the Association Time column to set a different time range other than the given options. The maximum time range configured for the association history data is seven days.
Click the download icon
to download the association history details as a .csv file.
Fetching details for the Avg. Speed, Total Data Used, and Avg. Signal Quality parameters might encounter a delay of 2 to 3 minutes due to processing the messages in queue. These values are fetched from the stats message and the details are received only if the session duration is more than 5 minutes. Sometimes, these values are not available for 15 minutes if the Aruba Central (on-premises) has not received the message from the device.
Filtering Options:
- The
icon allows to filter a particular item in the column. - The
icon allows to sort the items of a column in ascending or descending order.
The following table describes the parameters displayed in Association History.
Column |
Description |
Username |
Username of the client. |
Role |
Role of the client. |
Association Time |
Time stamp of when the client associated or roamed. |
Disassociation Time |
Time stamp of when the client disassociated or roamed. |
Session Duration |
Time duration of the connection. |
Device |
Device to which the client was connected. |
VLAN |
VLAN of the device to which the client was connected. |
SSID |
SSID to which the client was connected. |
LAN IP address of the client. |
Controller |
Name of the controller. |
Avg. Speed |
Average speed of the data transferred. |
Total Data Used |
Total data received and transmitted. |
Avg. Signal Quality |
Average SNR in dBDecibel. Unit of measure for sound or noise and is the difference or ratio between two signal levels.. |
Connection Mode |
Mode of connection. |
Client MAC Address |
MAC address. |
Channel Width |
Channel width while establishing the connection. |
Client OS |
OS of the client. |
MAC Vendor |
MAC address of the vendor. |
Cipher |
Encryption method. |
Key Management |
Key management information. |
AI Insights
The tab displays information about client performance and connectivity issues. AI Insights are displayed for a selected time period based on the time selected in . The user can select 3 hours, 1 week, 1 day, or 1 month to view the insight data. are categorized in high, medium, and low priorities depending on the number of occurrences.
Red—High priority -
Orange—Medium priority -
Yellow—Low priority
Each insight report specific details on the occurrences of these events for ease in debugging. For more information, see The AI Insights Dashboard
The client page displays the following insights:
- Clients with High Wi-Fi Security Key-Exchange Failures
- Clients with High 802.1X Authentication Failures
- Clients with DHCP Server Connection Problems
- Clients with High Number of MAC Authentication Failures
Live Client Monitoring
Click to start live monitoring of the client. Live monitoring is supported only if the Instant AP is running 8.4.0.0 firmware version. Live monitoring stops after 15 minutes. At any point, you can click Stop Live to go back to the historical view.
Five seconds after you start live monitoring, the following data starts getting populated:
- Throughput
- Signal to Noise Ratio (SNR)
Live Health Bar
The Live Health Bar is present in the Summary page for a wireless client. It provides live data every 5 seconds for a session duration of 15 minutes.
To launch the Live Health Bar:
- In the app, set the filter to one of the options under , , or . For all devices, set the filter to .
- Under , click . The page is displayed.
- By default, the table displays a unified list of clients.
- Click the client name to view the client details page. If there are many clients connected to the network, click to filter the clients connected to the wireless network.
- Enter the client name in the column and then click the client name.
The contextual dashboard for the selected client is displayed and opens the page by default.
Hover over the client name, the Health Bar pop-up appears. The pop-up displays the latest values that is updated every 5 seconds.
The Live Health Bar session is for 15 minutes only, after that time period, the refresh icon appears. If you click the refresh icon, the Live Health Bar session restarts where the values are updated every 5 seconds.
- Click the pin icon to pin the Health Bar to the Summary page for the constant view.
The parameters available in the Live Health Bar are:
- Connection status icon
To disconnect a wireless client from an online AP:
- Click the name of the wireless client to open the corresponding page. If there are many clients connected to the network, click to filter the clients connected to the wireless network, enter the client name in the column, and click the client name.
- From the drop-down list, click .
The drop-down is disabled if the AP is offline.
To disconnect a wireless client, ensure that there is an established Websocket connection from the controller to Aruba Central.
To block a wireless client from an online AP:
- Click the list icon to view the clients table.
The clients is unblocked from the network.
To remove a client from the blocked status, select the blocked client and click from the drop-down list in the Client Details page.
Applications
The page consists of the , and AirGroup tab.
Visibility
The dashboard provides a summary of client traffic and their data usage to and from applications, and websites. You can also analyze the client traffic flow using the graphs displayed in the dashboard. The tab consists of a list view and a graph view. The dashboard displays metrics and graphs related to client traffic flow in the following sections:
For more information about enabling , list of supported Instant APs, and the data displayed on the and sections, see Application Visibility.
UCC
The tab displays the detailed call records for the client if any. To view this data, ensure that the application service is enabled on the APs. The following table describes the information displayed in each session:
Section |
Description |
Displays the total number of calls. The call quality is displayed as: Good Fair Poor Unknown |
Displays the health of the client. |
Displays the type of the call or session. For example, audio, or video, or desktop sharing. |
Displays the quality of the call. |
AirGroup
The displays the details of the servers a client is connected to. The following table describes the information displayed in each session:
Section |
Description |
Displays the host name. |
Displays the MAC address of the server the client is connected to. |
Displays the IP address. |
Displays the user role assigned to the client. |
Displays the type of service. |
Displays the connected VLAN details. |
Displays the network the client is connected to. Name of the AP that broadcasts the SSID to which the client is connected. |
Events
In the page, the table displays the following columns by default: , , and . Click the ellipsis icon to perform additional operations:
- —Adjusts the column width of the table to fit the page evenly.
- —Resets the table view to the default columns.
If a filter icon appears next to the column header, click it and enter the filter criteria or select a filter criteria. The following table describes the information displayed in each event:
Section |
Description |
Displays the time at which the event occurred. |
Displays the type of the event. |
Displays the detailed description of the event. |
Displays the MAC address of the device. |
Displays the BSSID. |
To download events into a CSVComma-Separated Values. A file format that stores tabular data in the plain text format separated by commas. format, click the download button. Aruba Central generates the CSV report of all the events for the selected client.
You can also filter the events based on the type of events, click the . Select the type of events from the list and click . The events under the selected categories get listed in the table.
