Supported Client Events for CAP and IAP Devices
Aruba Central (on-premises) provides an dashboard for viewing the events triggered from Campus Access Point (CAP) and Instant Access Point (IAP) devices.
The following table lists the client events that are supported for IAP and CAP in Aruba Central (on-premises):
Event |
Description |
CAP |
IAP |
802.11802.11 is an evolving family of specifications for wireless LANs developed by a working group of the Institute of Electrical and Electronics Engineers (IEEE). 802.11 standards use the Ethernet protocol and Carrier Sense Multiple Access with collision avoidance (CSMA/CA) for path sharing. Association rejected for client [Client MACMedia Access Control. A MAC address is a unique identifier assigned to network interfaces for communications on a network. ] to BSSIDBasic Service Set Identifier. The BSSID identifies a particular BSS within an area. In infrastructure BSS networks, the BSSID is the MAC address of the AP. In independent BSS or ad hoc networks, the BSSID is generated randomly. [BSSID] on channel [Channel] of AP hostname [Device Hostname]. |
Supported |
Supported |
802.11 Disassociation sent to client [Client MAC] from BSSID [BSSID] on channel [Channel] of AP hostname [Device Hostname]. |
Supported |
Supported |
802.11 Disassociation received from client [Client MAC] associated to BSSID [BSSID] on channel [Channel] of AP hostname [Device Hostname]. |
Supported |
Supported |
802.11 Authentication failed for client [Client MAC] on BSSID [BSSID] on channel [Channel] of AP hostname [Device Hostname]. |
Supported |
Supported |
De-authentication sent to client [Client MAC] from BSSID [BSSID] on channel [Channel] of AP hostname [Device Hostname]. |
Supported |
Supported |
De-authentication sent from client [Client MAC] associated to BSSID [BSSID] on channel [Channel] of AP hostname [Device Hostname]. |
Supported |
Supported |
Client [Client MAC] associated to BSSID [From BSSID (roamed from)] on channel [From Channel (roamed from)] of AP hostname [From Device Hostname (roamed from)] roamed successfully to BSSID [BSSID] on channel [Channel] of AP hostname [Device Hostname]. |
Supported |
Supported |
MAC Authentication failed for client [Client MAC] to Radius Server [Radius Server IP] through BSSID [BSSID] on channel [Channel] of AP hostname [Device Hostname]. |
Supported |
Supported |
802.1x Radius Reject received for client [Client MAC] on BSSID [BSSID] on channel [Channel] of AP hostname [Device Hostname]. |
Supported |
Supported |
802.1x Radius Timeout occurred for client [Client MAC] on BSSID [BSSID] on channel [Channel] of AP hostname [Device Hostname]. |
Supported |
Supported |
Captive PortalA captive portal is a web page that allows the users to authenticate and sign in before connecting to a public-access network. Captive portals are typically used by business centers, airports, hotel lobbies, coffee shops, and other venues that offer free Wi-Fi hotspots for the guest users. failure occurred for client [Client MAC] associated to BSSID [BSSID] of AP hostname [Device Hostname]. |
Supported |
Supported |
EAPExtensible Authentication Protocol. An authentication protocol for wireless networks that extends the methods used by the PPP, a protocol often used when connecting a computer to the Internet. EAP can support multiple authentication mechanisms, such as token cards, smart cards, certificates, one-time passwords, and public key encryption authentication. failure occurred for client [Client MAC] associated to BSSID [BSSID] on channel [Channel] of AP hostname [Device Hostname]. |
Supported |
Supported |
EAP response from client [Client MAC] associated to BSSID [BSSID] on channel [Channel] of AP hostname [Device Hostname] timed out. |
Not Supported |
Supported |
VoIPVoice over IP. VoIP allows transmission of voice and multimedia content over an IP network. call initiated from station [Source Client Name] ([Source Client IP]) to station [Destination Client Name] ([Destination Client IP]) on AP hostname [Device Hostname]. |
Not Supported |
Supported |
VoIP call terminated from station [Source Client Name] ([Source Client IP]) to station [Destination Client Name] ([Destination Client IP]) on AP hostname [Device Hostname]. |
Not Supported |
Supported |
DHCPDynamic Host Configuration Protocol. A network protocol that enables a server to automatically assign an IP address to an IP-enabled device from a defined range of numbers configured for a given network. acknowledgment received from DHCP server [DHCP Server IP] for client [Client MAC] ([Client IP]) associated to BSSID [BSSID] on channel [Channel] of AP hostname [Device Hostname]. |
Supported |
Supported |
DHCP NACK to DHCP server [DHCP Server IP] from client [Client MAC] ([Client IP]) associated to BSSID [BSSID] on channel [Channel] of AP hostname [Device Hostname]. |
Supported |
Supported |
DHCP declined from DHCP server [DHCP Server IP] for client [Client MAC] ([Client IP]) associated to BSSID [BSSID] on channel [Channel] of AP hostname [Device Hostname]. |
Supported |
Supported |
DNSDomain Name System. A DNS server functions as a phone book for the intranet and Internet users. It converts human-readable computer host names into IP addresses and IP addresses into host names. It stores several records for a domain name such as an address 'A' record, name server (NS), and mail exchanger (MX) records. The Address 'A' record is the most important record that is stored in a DNS server, because it provides the required IP address for a network peripheral or element. failure to [Domain Name] detected for client [BSSID] on BSSID [BSSID] of AP hostname [Device Hostname]. |
Not Supported |
Supported |
DHCP request to DHCP server [DHCP Server IP] from client [Client MAC] timed out. |
Supported |
Supported |
Blacklisted client [Client MAC] on AP hostname [Device Hostname] for SSIDService Set Identifier. SSID is a name given to a WLAN and is used by the client to access a WLAN network. [SSID name]. |
Not Supported |
Supported |
Fast Roaming failed for client [Client MAC] with roaming type [Roaming Type] on AP hostname [Device Hostname]. |
Not Supported |
Supported |
Client [Client MAC] roamed successfully to SSID [SSID name] on channel [Channel] of AP hostname [Device Hostname]. |
Not Supported |
Supported |
Client match attempted a [Steer Type] using [Steer Mode] for client [Client MAC] from radio BSSID [From BSSID] to radio BSSID [To BSSID] with result: [Steer Result]. |
Not Supported |
Supported |
Client match attempted a [Steer Type] using [Steer Mode] for client [Client MAC] from radio BSSID [From BSSID] to radio BSSID [To BSSID] which was rejected by the client with reason code [802.11v802.11v is an IEEE standard that allows client devices to exchange information about the network topology and RF environment. This information is used for assigning best available radio resources for the client devices to provide seamless connectivity. Move Result]. |
Not Supported |
Supported |
Client match attempted a [Steer Type] using [Steer Mode] for client [Client MAC] from radio BSSID [From BSSID] to radio BSSID [To BSSID] which resulted in the client moving to a different radio BSSID [Destination Radio BSSID]. |
Not Supported |
Supported |
