Wired Client Details
The wired client overview page displays the client summary details, applications, and events details for the selected client.
This section includes the following topics:
Viewing Clients Connected to Wired Networks
To view the details of a client connected to the wired network:
- In the app, use the filter bar to select a group or a device.
- Under , click . The clients overview page is displayed.
- Click the list icon to view the clients table.
- By default, the table displays a unified list of clients for the selected group.
- Click the name of the wired client to open the corresponding page. If there are many clients connected to the network, click to filter the clients connected to the wired network, enter the client name in the column, and click the client name.
The wired client details page displays the client details summary and the client sessions information.
Summary
The client summary page displays the following information:
Wired Client Health Bar
Field |
Description |
Connection status icon |
Displays the icons with the connection status of the client. Connection status is updated immediately on state change. The available statuses are:
Name of the port through which the is connected. |
Name of the controller to which the client is connected. Click the name of the controller to view the device details page. |
Refresh icon |
Refreshes the data on the Health Bar for the wired client. |
Overview
The tab consists of the following sections.
Section |
Description |
Displays the data path of the client in the network. Click the device icon to view the corresponding device details page. The data path can be one of the following:
Displays the following information:
Applications
To view application usage metrics for the client connected to the wired network, enable .
The tab consists of two sections:
- —Displays a table with details on the client traffic flow to and from various applications. Click the bar graph icon to view bar graphs indicating the traffic flow.
- —Displays a table with details on client traffic flow and their data usage by various websites. Click the bar graph icon to view bar graphs indicating the data usage by various websites.
For more information about enabling , list of supported Instant APs, and the data displayed on the and sections, see Application Visibility.
UCC
The tab displays the detailed call records for the client if any. To view this data, ensure that the application service is enabled on the APs. The following table describes the information displayed in each session:
Section |
Description |
Displays the total number of calls. The call quality is displayed as: Good Fair Poor Unknown |
Displays the health of the client. |
Displays the type of the call or session. For example, audio, or video, or desktop sharing. |
Displays the quality of the call. |
AirGroup
The displays the details of the servers a client is connected to. The following table describes the information displayed in each session:
Section |
Description |
Displays the host name. |
Displays the MAC address of the server the client is connected to. |
Displays the IP address. |
Displays the user role assigned to the client. |
Displays the type of service. |
Displays the connected VLAN details. |
Displays the network the client is connected to. Name of the AP that broadcasts the SSIDService Set Identifier. SSID is a name given to a WLAN and is used by the client to access a WLAN network. to which the client is connected. |
Events
The page displays the details of events generated by the AP and client association. By default, the table displays the following columns: , , and . Click the ellipsis icon to perform additional operations:
- —Adjusts the column width of the table to fit the page evenly.
- —Resets the table view to the default columns.
If a filter icon appears next to the column header, click it and enter the filter criteria or select a filter criteria. The following table describes the information displayed in each event.
Section |
Description |
Displays the time at which the event occurred. |
Displays the type of the event. |
Displays the detailed description of the event. |
Displays the MAC address of the device. |
To download events into a CSVComma-Separated Values. A file format that stores tabular data in the plain text format separated by commas. format, click the download button. Aruba Central (on-premises) generates the CSV report of all the events for the selected client.
Tools
The page is automatically filtered based on the client you select. This enables network administrators to perform checks on the client and debug client connectivity issues. For more information, see Using Troubleshooting Tools.
