The Label Dashboard
In the Network Operations app, the label dashboard is displayed when the filter is set to any of the options under . The label dashboard displays information related to all devices configured for that label in Aruba Central.
Left Navigation Menu |
First-Level Tabs |
Description |
Displays details such as the bandwidth usage, client count, top APs by usage, top 5 clients, top AP clusters by usage, top AP clusters by clients, and WLANWireless Local Area Network. WLAN is a 802.11 standards-based LAN that the users access through a wireless connection. network details. By default, the graphs are plotted for a time range of 3 hours. To view the graphs for a different time range, click the Time Range filter. For more information, see Global—Summary |
Displays the access points information in the following views: |
Displays the switches information in the following views: |
Displays the controller information in the following view: |
Displays information about all the clients connected to the devices configured for the group. For more information, see All Clients. |
Displays a variety of charts and lists that allow you to assess the quality of calls in the network. For more information, see Unified Communications. |
Identify and act on interfering devices that can be later considered for investigation, restrictive action, or both. Once the interfering devices are discovered, Aruba Central sends alerts to the network administrators about the possible threat and provides essential information needed to locate and manage the threat. For more information, see Rogue Detection and Classification. |
Displays all types of alerts and events generated for events pertaining to device provisioning, configuration, and user management. For more information, see Alerts & Events. |
Enables network administrators and users with troubleshooting permission to perform troubleshooting or diagnostics tests on devices and networks managed by Aruba Central. For more information, see Using Troubleshooting Tools. |
Enables you to create various types of reports. You can create recurrent reports or configure the reports to run on demand. For more information, see Reports . |
