Aruba Central Online Help
The Global Dashboard
In the Network Operations app, the global dashboard is displayed when the filter is set to Global. The global dashboard displays information related to all devices registered to that account in Aruba Central.
Some tabs may not be seen in your dashboard view if you are not an administrator for the Aruba Central account.
Table 1: Contents of the Global Dashboard
Left Navigation Menu
First-Level Tabs
Description
Manage > Overview
Network Health
Displays information of the networks sorted by site, including information on network devices and WANWide Area Network. WAN is a telecommunications network or computer network that extends over a large geographical distance. connectivity of individual sites.
For more information, see Network Health.
Summary
Displays details such as the bandwidth usage, client count, top APs by usage, top 5 clients, top AP clusters by usage, top AP clusters by clients, and WLANWireless Local Area Network. WLAN is a 802.11 standards-based LAN that the users access through a wireless connection. network details. By default, the graphs are plotted for a time range of 3 hours. To view the graphs for a different time range, click the Time Range Filter.
For more information, see Global—Summary
Manage > Devices
Access Points
Displays the access points information in the following views:
Summary view: Monitoring APs in Summary View
List view: Monitoring APs in List View
Switches
Displays the switches information in the following views:
Summary view: Monitoring Switches in Summary View
List view: Monitoring Switches in List View
Controllers
Displays the controller information in the following view:
Summary view: Controller > Overview > Summary
Manage > Clients
Clients
Displays information about all the clients connected to the devices configured for the group.
For more information, see All Clients.
Manage > Applications
Visibility
Provides a summary of client traffic and their data usage to and from applications and websites. Also, analyzes the client traffic flow using the graphs displayed.
For more information, see Application Visibility.
UCC
Monitors voice, video, and application sharing sessions, provides traffic visibility, and allows you to prioritize the required sessions. The app also leverages the functions of the service engine on the cloud platform to provide visual metrics for analytical purposes.
For more information, see Unified Communications.
Manage > Security
RAPIDs
Helps to identify and act on interfering devices that can be later considered for investigation, restrictive action, or both.
For more information, see Rogue Detection and Classification.
Firewall
Monitors traffic coming into and going out of the Aruba Central-managed network and acts as an investigative resource for users to track blocked sessions within the network.
For more information, see Configuring Firewall Parameters for Wireless Network Protection.
Analyze > Alerts and Events
Alerts & Events
Displays all types of alerts and events generated for events pertaining to device provisioning, configuration, and user management.
For more information, see Alerts & Events.
Analyze > Audit Trail
Audit Trail
Shows the total number logs generated for all device management, configuration, and user management events triggered in Aruba Central.
For more information, see Viewing Audit Trail.
Analyze > Tools
Network Check
Device Check
Commands
Enables network administrators and users with troubleshooting permission to perform troubleshooting or diagnostics tests on devices and networks managed by Aruba Central.
For more information, see Using Troubleshooting Tools.
Analyze > Reports
Reports
Enables you to create various types of reports. You can create recurrent reports or configure the reports to run on demand.
For more information, see Reports .
Maintain > Firmware
Access Points
Switches
Controllers
Provides an overview of the latest supported version of firmware for the device, details of the device, and the option to upgrade the device.
For more information, see Upgrading Device Firmware.
Maintain >Organization
Groups
A group in Aruba Central is the primary configuration element that functions as a container for device management, monitoring, and maintenance. Groups enable administrators to manage devices efficiently by using either a UI-based configuration workflow or CLI-based configuration template.
For more information, see Managing Groups.
Sites and Labels
A site refers to a physical location where a set of devices are installed; for example, campus, branch, or venue. Labels are tags attached to a device provisioned in the network. Labels determine the ownership, departments, and functions of the devices.
For more information, see Managing Sites and Managing Labels.
Certificates
Enables administrators to upload a valid certificate signed by a root CACertificate Authority or Certification Authority. Entity in a public key infrastructure system that issues certificates to clients. A certificate signing request received by the CA is converted into a certificate when the CA adds a signature generated with a private key. See digital certificate. so that devices are validated and authorized to use Aruba Central.
For more information, see Managing Certificates.
