Troubleshooting Switches
You can troubleshoot a switch using the Aruba Central UI.
To troubleshoot a switch, complete the following steps:
1. In the app, set the filter to one of the options under , , or . Ensure that the filter selection contains at least one switch. For all devices, set the filter to .
2. Under , click > .
A list of switches is displayed in the view.
3. In the Switches table, click the switch to troubleshoot.
The Switch Details page corresponding to the switch is displayed.
4. In the drop-down, click .
The page is displayed.
5. Select any command category in the pane and the pane displays the associated commands.
Aruba CX switches support only the show tech and show running-config commands. |
6. Click to add the selected commands to the pane.
7. If you have selected a command marked with either '*' or '+', enter the filtration parameters as displayed in the dialog box. For more information on filtering commands, see Mandatory filters— Commands marked with '*'.
8. (Optional) Select command(s) and click < Remove to remove selected command(s) or click to clear the pane.
9. (Optional) To set a frequency for automatically executing the troubleshooting commands:
a. Click the check box.
b. Specify an interval for executing the troubleshooting commands. You can also specify how frequently the commands must be executed during a given interval.
c. Click to modify the values in all the fields, and for canceling all the repeats. Click the stop icon to stop a particular repeat.
10. Click . The output is displayed in the section.
For information about viewing and downloading the output, see Viewing the Device Output.
