Access Point > Overview > Floor Plan
In the AP dashboard, the tab provides information regarding the current location of the Instant AP.
Viewing the Overview > Floor Plan Tab
To navigate to the tab in the AP dashboard, complete the following steps:
1. In the app, set the filter to one of the options under , , or . For all devices, set the filter to . Ensure that the filter selected contains at least one active access point.
2. Under , click > .
A list of access points is displayed in the view.
3. Click an access point listed under .
The dashboard context for the access point is displayed.
4. In the access point dashboard context, click the tab.
The tab is displayed.
To exit the AP dashboard, click the back arrow on the filter.
The tab displays a sitemap and the floor plan showing the current location of the Instant AP . The sitemap is derived from the Visual RFRadio Frequency. RF refers to the electromagnetic wave frequencies within a range of 3 kHz to 300 GHz, including the frequencies used for communications or Radar signals. application, if Visual RF service is enabled for the Aruba Central account. You can also edit the location of the Instant AP device by clicking the edit icon provided next to the address in the tab.
Actions
The drop-down list contains the following options:
—Reboots the access point. For more information, see Rebooting an Instant AP.
—Reboots the AP cluster. For more information, see Rebooting an Instant AP Cluster .
—Enables the administrator to generate a tech support dump required for troubleshooting the access point. For more information, see Tech Support for an Instant AP .
—Opens the remote console for a CLI session through SSHSecure Shell. SSH is a network protocol that provides secure access to a remote device. for an access point. For more information, see Opening a Remote Console.
Go Live
Aruba Central supports live monitoring of Instant APs that support Aruba Instant 8.4.0.0 firmware version and above. Aruba Central allows you to monitor live data of an AP updated at every 5 seconds. For more information, see Enabling Live Instant AP Monitoring.
