Access Point > Security > VPN
The tab provides information on VPNVirtual Private Network. VPN enables secure access to a corporate network when located remotely. It enables a computer to send and receive data across shared or public networks as if it were directly connected to the private network, while benefiting from the functionality, security, and management policies of the private network. This is done by establishing a virtual point-to-point connection through the use of dedicated connections, encryption, or a combination of the two. connections associated with the virtual controller along with information on the tunnels and the data usage through each of the tunnels.
Viewing the Security > VPN Tab
To navigate to the tab, complete the following steps:
1. In the app, set the filter to one of the options under , , or . For all devices, set the filter to . Ensure that the filter selected contains at least one active access point.
2. Under , click > .
A list of access points is displayed in the view.
3. Click an access point listed under .
The dashboard context for the access point is displayed.
4. Under , click > .
The tab is displayed.
The tab provides the following information:
—The section displays information on tunnels with the following details:
—Total tunnels established.
—Number of tunnels currently active.
—Number of tunnels currently inactive.
—Number of peer tunnels currently active.
The table displays information on tunnels with the following columns:
—The type of the tunnels used in the VPN. For example, primary, secondary, or backup.
—The status of the tunnel.
—The source address of the tunnel.
—The destination address of the tunnel.
—The graph indicates the successful data usage per VPN in MbpsMegabits per second for the primary or backup tunnel selected from the drop-down list. The displays a linear graph of sent and received data in the virtual private network.
