Access Point > Overview > RF
In the AP dashboard, the tab provides details corresponding to 2.4 GHzGigahertz., 5 GHz, and 5 GHz Secondary radios of the AP.
Viewing the Overview > RF Tab
To navigate to the tab in the AP dashboard, complete the following steps:
1. In the app, set the filter to one of the options under , , or . For all devices, set the filter to . Ensure that the filter selected contains at least one active access point.
2. Under , click > .
A list of access points is displayed in the view.
3. Click an access point listed under .
The dashboard context for the access point is displayed.
4. In the access point dashboard context, click the tab.
The tab is displayed.
To exit the AP dashboard, click the back arrow on the filter.
The tab provides the following details:
Channel Utilization
The graph indicates the percentage of channel utilization for the selected time range from the time range filter.
Noise Floor
The graph indicates the noise floor detected in the network to which the device belongs.
Frames - 802.11
The line graph indicates the trend of frames transmitted through the network. The frames can be one of the following types: , , and . The graph indicates the status of data frames that were dropped, encountered errors, retried to be transferred, in a wireless network.
Channel Quality
The graph indicates the quality of channel in percentage.
When you hover over the , , , and graphs, it displays specific data for the selected timestamp. |
The tri-radio feature is available only for AP-555. In the tab, the tab is available only if the tri-radio mode is enabled. For more information, see Tri-Radio Mode. |
Actions
The drop-down list contains the following options:
—Reboots the access point. For more information, see Rebooting an Instant AP.
—Reboots the AP cluster. For more information, see Rebooting an Instant AP Cluster .
—Enables the administrator to generate a tech support dump required for troubleshooting the access point. For more information, see Tech Support for an Instant AP .
—Opens the remote console for a CLI session through SSHSecure Shell. SSH is a network protocol that provides secure access to a remote device. for an access point. For more information, see Opening a Remote Console.
Go Live
Aruba Central supports live monitoring of Instant APs that support Aruba Instant 8.4.0.0 firmware version and above. Aruba Central allows you to monitor live data of an AP updated at every 5 seconds. For more information, see Enabling Live Instant AP Monitoring.
