doc title Help Center
The Group Dashboard
In the Network Operations app, the group dashboard is displayed when the filter is set to a UI or template group. A template group is marked by a superscript TG tag. The following table lists all the available menu items in the Network Operations app for the group dashboard.
Some tabs may not be seen in your dashboard view if you are not an administrator for the Aruba Central account.
Table 1: Contents of the Group Dashboard
Left Navigation Menu
First-Level Tabs
Description
Manage > Overview
Summary
Displays details such as the bandwidth usage, client count, top APs by usage, top 5 clients, top AP clusters by usage, top AP clusters by clients, and WLANWireless Local Area Network. WLAN is a 802.11 standards-based LAN that the users access through a wireless connection. network details. By default, the graphs are plotted for a time range of 3 hours. To view the graphs for a different time range, click the Time Range filter.
For more information, see Global—Summary
Manage > Devices
Access Points
Displays the access points information in the following views:
Summary view: Monitoring Access Points in Summary View
List view: Monitoring Access Points in List View
Config view: Provisioning APs
Switches
Displays the switches information in the following views:
Summary view: Viewing the Switches Summary Page
List view: Viewing the Switches List Page
Config view: Getting Started with Aruba Switch Deployments
Controllers
Displays the controller information in the following view:
Summary view: Controller > Overview > Summary
Manage > Clients
Clients
Displays information about all the clients connected to the devices configured for the group.
For more information, see All Clients.
Manage > Applications
Visibility
Provides a summary of client traffic and their data usage to and from applications and websites. Also, analyzes the client traffic flow using the graphs displayed.
For more information, see Application Visibility.
Manage > Security
RAPIDs
Helps to identify and act on interfering devices that can be later considered for investigation, restrictive action, or both.
For more information, see Rapids.
Analyze > Alerts and Events
Alerts & Events
Displays all types of alerts and events generated for events pertaining to device provisioning, configuration, and user management.
For more information, see Alerts & Events.
Analyze > Audit Trail
Audit Trail
Shows the total number logs generated for all device management, configuration, and user management events triggered in Aruba Central.
For more information, see Viewing Audit Trail.
Analyze > Tools
Network Check
Commands
Enables network administrators and users with troubleshooting permission to perform troubleshooting or diagnostics tests on devices and networks managed by Aruba Central.
For more information, see Home.
Analyze > Reports
Reports
Enables you to create various types of reports. You can create recurrent reports or configure the reports to run on demand.
For more information, see Reports .
Maintain > Firmware
Access Points
Switches
Controllers
Provides an overview of the latest supported version of firmware for the device, details of the device, and the option to upgrade the device.
For more information, see Upgrading Device Firmware.
