Configuring Device Profile
Device profile configuration allows you to dynamically detect an Aruba AP, which is directly connected to the switch, and apply predefined configurations to ports on which the Aruba AP is detected.
Configuration changes made on the page will always take precedence over changes made on other configuration pages. |
To configure device profile, complete the following procedure:
1. In the app, select one of the following options:
To select a switch group in the filter:
a. Set the filter to a group containing at least one switch.
The dashboard context for the group is displayed.
b. Under , click > .
c. Click the icon to view the switch configuration dashboard.
To select a switch in the filter:
a. Set the filter to or a group containing at least one switch.
A list of switches is displayed in the view.
c. Click a switch under .
The dashboard context for the switch is displayed.
d. Under , click .
The tabs to configure the switch is displayed.
2. Click . The Device Profile page is displayed.
3. Slide the toggle switch to on to enable the device profile support for a device type. By default, the device profile is disabled.
4. Configure the following parameters.
| Name | Description | Value |
The name of the profile configured.You cannot modify this field. If no other device profile is mapped to the device type, the default device profile default-ap-profile is associated with the device type. associated with the device type. |
Inherited from switch. |
Type of the device supported. |
The only device type supported is Aruba AP. |
The untagged member of the VLAN. |
Select from drop-down list. The default value is 1. |
The PoEPower over Ethernet. PoE is a technology for wired Ethernet LANs to carry electric power required for the device in the data cables. The IEEE 802.3af PoE standard provides up to 15.4 W of power on each port. priority for the device port. |
, or . |
Indicates whether jumbo packet handling is enabled for the VLAN interface. |
Toggle switch to the on or off position |
5. Click .
