Configuring Loop Protection on Aruba Switch Ports
Enabling Loop Protection consumes CPUCentral Processing Unit. A CPU is an electronic circuitry in a computer for processing instructions. resources. |
Loop protection provides protection against loops by transmitting loop protocol packets out of ports. For switches provisioned in UI groups, administrators can enable or disable loop protection on the switch ports or trunks by using the menu options available under app, > > .
Loop protection is always disabled by default on Aruba switches. To configure loop protection for switches provisioned in the UI groups:
1. In the app, select one of the following options:
To select a switch group in the filter:
a. Set the filter to a group containing at least one switch.
The dashboard context for the group is displayed.
b. Under , click > .
c. Click the icon to view the switch configuration dashboard.
To select a switch in the filter:
a. Set the filter to or a group containing at least one switch.
A list of switches is displayed in the view.
c. Click a switch under .
The dashboard context for the switch is displayed.
d. Under , click .
The tabs to configure the switch is displayed.
2. Click > . The page is displayed.
3. Depending on whether you want to configure a port or trunk, complete one of the following steps:
In the tab, select the port(s), click .
In the tab, select the trunk(s), click .
Name |
Description |
Value |
The number assigned to the switch port. |
0 – 65535 |
Enables or disables loop protection. |
or Default: |
Name of the trunk group to which the port belongs. |
Dependent on the switch type. |
Name |
Description |
Value |
or Default: |
4. Set loop protection to in the Loop Protection drop-down.
5. Click .
6. Click .
