doc title Help Center
Configuring Switches in UI Groups
This section describes the configuration and viewing procedures for the switches in the UI groups.
Aruba Central does not support preconfigured switches in a UI group. If you want to move a switch from a template group to a UI group, you must clear the switch configuration, delete the device from Aruba Central, and then provision the switch as a new device in a UI group.
To configure or view properties of the switches provisioned in UI groups, perform the following procedure:
1. In the Network Operations app, select one of the following options:
To select a switch group in the filter:
a. Set the filter to a group containing at least one switch.
The dashboard context for the group is displayed.
b. Under Manage, click Devices > Switches.
To select a switch in the filter:
a. Set the filter to Global or a group containing at least one switch.
c. Click a switch under Device Name.
The dashboard context for the switch is displayed.
d. Under Manage, click Device.
The tabs to configure the switch is displayed.
2. Click the configuration icon to edit the switch properties. Tabs to access different configuration pages are displayed.
The following table describes the different configuration pages and their functions.
Table 1: Tabs for Configuring Switches Provisioned in a UI Group
Tab
Function
Switches
Configure or view general switch properties, such as, hostname, type of IP addressing, and so on.
See Configuring or Viewing the Switch Properties.
Stacks
Create stacks, add members, or view stacking details such as stack type, stack id, topology and so on.
See Provisioning Switch Stacks in Aruba Central.
Ports
Assign or view port properties, such as, , access policies, and trunk groups.
See Configuring Switch Ports on Aruba Switches
PoE
Configure or view PoE settings for each port.
See Configuring PoE Settings on Aruba Switch Ports.
Trunk Groups
Configure or view trunk groups and their associated properties, such as, members of the trunk group, type of trunk group and so on.
See Configuring Trunk Groups on Aruba Switches in UI Groups.
VLANs
Configure or view and the associated ports and access policies.
See Configuring VLANs on Aruba Switches.
Spanning Tree
Configure or view spanning tree protocol and its associated properties.
See Enabling Spanning Tree Protocol on Aruba Switches in UI Groups.
Loop Protection
Configure or view loop protection and its associated properties.
See Configuring Loop Protection on Aruba Switch Ports.
Access Policy
Add or view access policies.
See Configuring Access Policies on Aruba Switches.
DHCP Snooping
Configure or view snooping, authorized DHCP servers IP addresses, and their associated properties.
See Configuring DHCP Snooping.
Port Rate Limit
View or specify bandwidth to be used for inbound or outbound traffic for each port.
See Configuring Port Rate Limit on Aruba Switches in UI Groups.
Radius
Configure or view (Remote Authentication Dial-In User Service) server settings on switches.
See Editing a RADIUS Server Settings.
Tunnel Node Server
Configure or view tunneled node on switches.
See Configuring Switches in UI Groups.
Authentication
Configure or view authentication and authentication for switches.
See 802.1X Authentication.
Access/DNS
Configure or view the administrator and operator logins.
See Configuring System Parameters for a Switch.
Time
Configure time synchronization in switches.
See Predefined DST Rules.
SNMP
Add or view community and its trap destination.
See Configuring SNMP on Aruba Switches.
CDP
Configure and its associated properties.
See Configuring CDP.
Routing
Configure or view a specific routing path to a gateway.
See Configuring Routing on Aruba Switches.
DHCP Pools
Add or view a DHCP pool and its associated properties.
See Configuring DHCP Pools on Aruba Switches.
IGMP
See Configuring IGMP on Aruba Switches.
QoS
Create traffic policies. define QoS classes and change the priorities of traffic on switches.
See Creating a QoS Traffic Policy.
Device Profile
Configure or view device profile settings on switches.
Configuration Audit
View configuration sync errors and overrides.
See Verifying Device Configuration Status.
