Configuring Access Policies on Aruba Switches
Aruba Central does not support access policy configuration on Aruba Mobility Access Switches. |
To restrict certain types of traffic on physical ports of Aruba switches, you can configure ACLsAccess Control List. ACL is a common way of restricting certain types of traffic on a physical port. from the Aruba Central UI.
To create an access policy, complete the following steps:
1. In the app, select one of the following options:
To select a switch group in the filter:
a. Set the filter to a group containing at least one switch.
The dashboard context for the group is displayed.
b. Under Manage, click > .
c. Click the icon to view the switch configuration dashboard.
To select a switch in the filter:
a. Set the filter to or a group containing at least one switch.
A list of switches is displayed in the view.
c. Click a switch under .
The dashboard context for the switch is displayed.
d. Under , click .
The tabs to configure the switch is displayed.
2. Click > . The Access Policy page is displayed.
3. Click + to add a new access policy. The page is displayed.
4. Enter a name for the policy.
5. Click .
6. To add a rule to the access policy, click + under , and configure the following parameters:
Name |
Description |
Value |
Select a source of the traffic for which you want to an access rule. |
, , or For , specify IP address and mask For , specify IP address |
Select a destination. |
Select the type of protocol. Some protocols also require source and destination ports. |
Select from drop-down. |
The action that the switch must perform on the traffic received at a port. |
or |
7. Click .
8. Click .
The access policies must be applied to a switch port and the VLANVirtual Local Area Network. In computer networking, a single Layer 2 network may be partitioned to create multiple distinct broadcast domains, which are mutually isolated so that packets can only pass between them through one or more routers; such a domain is referred to as a Virtual Local Area Network, Virtual LAN, or VLAN. assigned to a port. For more information on access policy assignment to ports and VLANs, see the following topics:
