Configuring SNMP on Aruba Switches
You can configure SNMPSimple Network Management Protocol. SNMP is a TCP/IP standard protocol for managing devices on IP networks. Devices that typically support SNMP include routers, switches, servers, workstations, printers, modem racks, and more. It is used mostly in network management systems to monitor network-attached devices for conditions that warrant administrative attention. community settings and trap settings through the UI.
SNMP settings can be configured only when switch is installed with the minimum supported firmware version of 16.09 or later. |
To enable SNMP on a switch, complete the following steps:
1. n the app, select one of the following options:
To select a switch group in the filter:
a. Set the filter to a group containing at least one switch.
The dashboard context for the group is displayed.
b. Under , click > .
c. Click the icon to view the switch configuration dashboard.
To select a switch in the filter:
a. Set the filter to or a group containing at least one switch.
A list of switches is displayed in the view.
c. Click a switch under .
The dashboard context for the switch is displayed.
d. Under , click .
The tabs to configure the switch is displayed.
2. Click > . The page is displayed.
3. Move the toggle switch to the on position.
Configuring community settings
You can add or delete SNMP communities to restrict access to the switch.
Adding a read community
To add an SNMP community, complete the following steps:
1. In the page, expand the accordion.
The table displays the list of communities that have read-only access.
2. To add a read community, click +.
The window is displayed.
3. Enter the name of the community in the text box and click .
Deleting a read community
To delete a read community, click the delete icon for the community you want to delete.
Configuring trap settings
You can configure authentication, trap destination, and trap categories using trap settings.
Adding a trap destination
To add a trap destination, complete the following steps:
The table displays the following information:
—The destination IP address for sending the trap.
—The community name used for sending the trap.
2. To add a read destination, click +.
3. Configure the parameters listed in step 1.
4. Click
Deleting a trap destination
To delete a trap destination, point to the row for the trap destination, and click the delete icon in the column.
Enabling trap categories
To enable trap categories, complete the following steps:
1. In the accordion, select the authentication type used to connect to the SNMP server from the drop-down.
2. In the table, select the checkbox for the trap category you want to enable.
3. Click .
The availability of trap categories differs based on the device model. |
