Configuring Time Synchronization on Aruba Switches
Time synchronization in a switch ensures maintaining a uniform time among all interoperating devices. Aruba Central offers the Simple Network Time Protocol (SNTPSimple Network Time Protocol. SNTP is a less complex implementation of NTP. It uses the same , but does not require the storage of state over extended periods of time.) time synchronization protocol for switches. In SNTP, Aruba Central supports broadcast, unicast, and DHCPDynamic Host Configuration Protocol. A network protocol that enables a server to automatically assign an IP address to an IP-enabled device from a defined range of numbers configured for a given network. modes.
To configure time synchronization in a switch, complete the following steps:
1. In the app, select one of the following options:
To select a switch group in the filter:
a. Set the filter to a group containing at least one switch.
The dashboard context for the group is displayed.
b. Under , click > .
c. Click the icon to view the switch configuration dashboard.
To select a switch in the filter:
a. Set the filter to or a group containing at least one switch.
A list of switches is displayed in the view.
c. Click a switch under .
The dashboard context for the switch is displayed.
d. Under , click .
The tabs to configure the switch is displayed.
2. Click > . The Time page is displayed.
3. Configure the following parameters.
Name |
Description |
Value |
The synchronization method or protocol to use for synchronizing the time on the switch. |
SNTP |
The operating mode for connecting to a time server. The following modes are supported: —The switch acquires time updates from the data that any time server broadcasts to the network. The switch uses the time data from the first server detected and ignores others. If the poll interval expires thrice without the switch acquiring a time update from the first server detected, the switch accepts a time update from the next server broadcast. To use the mode, the switch and the time server must be in the same subnetSubnet is the logical division of an IP network.. Also, the time server must be configured to broadcast time updates to the network broadcast address. —The switch acquires time updates from a specific server for time synchronization. This mode requires at least one server address to be configured in the field. —The switch attempts to acquire a time server IP address from the DHCP server. If the switch receives a server address, it polls the server for time updates according to the poll interval. If the switch does not receive a time server IP address, it cannot perform time synchronization updates. —Time synchronization is disabled. |
Broadcast, Unicast, DHCP, and Disabled Default: DHCP |
IP address of the time server that the switch accesses for obtaining time synchronization updates. This field is applicable only when you select the mode for synchronization. You can configure a maximum of three time server IP addresses. When you add more than one IP address, the priority that the switch considers in selecting the IP address is the order in which you add the IP address. Therefore, the first IP address that you add will be priority 1, second IP address will be priority 2, and so on. You can delete the IP addresses by clicking the delete icon corresponding to the address. When more than one IP addresses are added, you must first delete the IP address you added last. |
IPv4 address |
The time zone corresponding to the location of the switch. |
Time zone selected from the drop-down. |
The rule that the switch uses to adjust the time for Daylight Saving Time (DSTDaylight Saving Time. DST is also known as summer time that refers to the practice of advancing clocks, so that evenings have more daylight and mornings have less. Typically clocks are adjusted forward one hour near the start of spring and are adjusted backward in autumn. ). For information about the predefined and user-defined times, see Predefined DST Rules. When you select the option, you must configure the beginning and ending months and dates for DST changes in the and fields. All DST rules begin and end at 2 a.m. on the configured dates. |
Alaska, Canada and Continental US, Middle Europe and Portugal, Southern Hemisphere, Western Europe, and User-defined. |
The beginning month and date for the user-defined DST changes. This field appears only when you select in the field. |
Month and date selected from the drop-down. |
The ending month and date for the user-defined DST changes. This field appears only when you select in the field. |
4. Click .
Following are the details of the beginning and ending days for the predefined DST rules:
Predefined DST Rule Name |
Description |
Begin DST at 2 a.m. on March 8. End DST at 2 a.m. on November 1. |
Begin DST at 2 a.m. on March 25. End DST at 2 a.m. on September 24. |
Begin DST at 2 a.m. on October 25. End DST at 2 a.m. on March 1. |
Begin DST at 2 a.m. on March 25. End DST at 2 a.m. on October 25. |
