Configuring Switch Ports on Aruba Switches
To view the port details of a switch, complete the following steps:
1. In the app, select one of the following options:
To select a switch group in the filter:
a. Set the filter to a group containing at least one switch.
The dashboard context for the group is displayed.
b. Under , click > .
c. Click the icon to view the switch configuration dashboard.
To select a switch in the filter:
a. Set the filter to or a group containing at least one switch.
A list of switches is displayed in the view.
c. Click a switch under .
The dashboard context for the switch is displayed.
d. Under , click .
The tabs to configure the switch is displayed.
2. Click > . The page is displayed with the list of ports configured on the switch.
For Aruba switches, the page displays the following information:
Name |
Description |
Value |
Indicates the number assigned to the switch port. |
Dependent on the switch type. |
Name of the port for easy identification. You can add or edit port names. However, do not delete port names as it may cause config push to fail. The config push failure may also arise if you move a switch from a group configured with port names to a new group. This issue is only applicable to switch firmware versions earlier than 16.08.0002. |
For example:
Allows you to set the operational status of the port. |
or |
Allows you to set the maximum bandwidth of the port traffic. |
Select from drop-down. Default is . |
Indicates whether the port is tunneled or not. |
or To configure a Tunnel Node Server, see Configuring Switches in UI Groups |
Status of port to filter DHCPDynamic Host Configuration Protocol. A network protocol that enables a server to automatically assign an IP address to an IP-enabled device from a defined range of numbers configured for a given network. messages received at the port. |
or |
Allows you to apply an existing access policy for the inbound traffic on the port. |
Select from drop-down. |
Allows you to apply an existing access policy for the outbound traffic on the port. |
Displays the name of the trunk group to which the port is assigned. |
To configure a Trunk Group, see Configuring Trunk Groups on Aruba Switches in UI Groups. |
3. Select the port row, click .The Edit Ports window is displayed.
4. Configure the required parameters.
5. Click .
