Configuring Tunnel Node Server on Aruba Switches
Aruba Central allows you to configure tunneled node on switches. The tunneled node connects to one or more client devices at the edge of the network and then establishes a secure Generic Routing Encapsulation (GREGeneric Routing Encapsulation. GRE is an IP encapsulation protocol that is used to transport packets over a network.) tunnel to the controlling concentrator server. You can configure Port-Based Tunnel using UI group.
To configure a tunneled node on the switch, complete the following steps:
1. In the app, select one of the following options:
To select a switch group in the filter:
a. Set the filter to a group containing at least one switch.
The dashboard context for the group is displayed.
b. Under , click > .
c. Click the icon to view the switch configuration dashboard.
To select a switch in the filter:
a. Set the filter to or a group containing at least one switch.
A list of switches is displayed in the view.
c. Click a switch under .
The dashboard context for the switch is displayed.
d. Under , click .
The tabs to configure the switch is displayed.
2. Click > . The Tunnel Node Server page is displayed.
3. Configure the following parameters.
| Name | Description | Value |
The mode of tunneling from the drop-down: —switch does not tunnel traffic. —Allows the switch to tunnel traffic to an Aruba controller on a per-port basis. |
or |
The IP address of the primary gateway. |
A valid IPv4 address |
The IP address of the backup gateway. This field is optional. |
4. Click .
