Configuring IGMP on Aruba Switches
By default, IGMP is disabled for all VLANs.
To enable IGMP for a VLAN, complete the following steps:
1. In the app, select one of the following options:
To select a switch group in the filter:
a. Set the filter to a group containing at least one switch.
The dashboard context for the group is displayed.
b. Under , click > .
c. Click the icon to view the switch configuration dashboard.
To select a switch in the filter:
a. Set the filter to or a group containing at least one switch.
A list of switches is displayed in the view.
c. Click a switch under .
The dashboard context for the switch is displayed.
d. Under , click .
The tabs to configure the switch is displayed.
2. Click . The IGMP page is displayed with the list of existing VLANs.
3. Select the VLAN row(s) for which you want to configure IGMP, and click .
4. Select or from the drop-down.
5. Click .
6. To configure the switch to filter unknown multicast messages, move the toggle switch to the on position.
7. Click .
