What's New in Aruba Central (on-premises) 2.5.4.3
New Features
The following sections provide an overview of the new features that are added to Aruba Central in this release.
Support for 9004 non-LTE Mobility Controller
Aruba Central (on-premises) supports the Aruba 9004 non-LTELong Term Evolution. LTE is a 4G wireless communication standard that provides high-speed wireless communication for mobile phones and data terminals. See 4G. Mobility Controller in discovery and monitoring. After Aruba Central (on-premises) discovers these controllers, you can receive diagnostics, reports, and triggers for these controllers.
For a complete list of supported products,
What's New in Aruba Central (on-premises) 2.5.4.2
New Features
Alerts and Events
The Enable All and Disable All buttons are added to the Access Point, Switch, Controller, and Central System tabs under the Alerts and Events > Config page of the WebUI. Click Enable All to enable all the alerts on a single click. Similarly, click Disable All to disable all the alerts.
For more information, see Configuring Alerts.
Bulk Replacement of APs
Aruba Central (on-premises) now allows bulk replacement of Campus APs and Remote APs by using one of the following pages in the WebUI:
- Manage> Overview > Device Replacement under Sites filter.
- Manage Sites under Maintain > Organization > Network Structure > Sites.
For more information, see Replacing APs in Bulk.
What's New in Aruba Central (on-premises) 2.5.4.0
Important Notes
It is recommended to upgrade all the Aruba Central (on-premises) nodes to 512 GB for optimum performance and using the 256 GB RAMRandom Access Memory. might result in degraded performance. Note that the 256 GB RAM will not be supported in upcoming releases.
New Features
AOS-CX 4100i and 6100 Platform Support
Aruba Central (on-premises) now supports configuring and monitoring AOS-CX 6100 Switch Series using UI options and MultiEdit mode. Aruba Central (on-premises) also supports configuring and monitoring AOS-CX 4100i Switch Series using UI options, MultiEdit mode, and templates.
For more information, see Supported AOS-CX Switch Platforms.
AOS-CX Stacking Configuration
In addition to onboarding pre-configured AOS-CX VSF stacks, Aruba Central now supports configuring and managing AOS-CX VSF stacks using UI options and templates.
VSF Stacking UI Configuration
You can now configure an AOS-CX VSF stack using UI group. The following stack-related configurations can be performed using the web UI:
- Creating a stack
- Adding a stack member
- Removing a stack member
- Modifying VSF links
- Changing the secondary member
For more information, see Configuring AOS-CX VSF Stacks Using UI Groups.
VSF Stacking Template Configuration
You can now configure an AOS-CX VSF stack using templates group. The following stack-related configurations can be performed using templates:
- Creating a stack
For more information, see, Configuring AOS-CX VSF Stacks Using Template Groups.
AOS-CX UI Configuration
The following new features are available for the AOS-CX UI group and device configuration.
Client Roles
Client roles allow administrators to assign network access to clients. A network administrator can create configuration profiles (roles) and associate them to clients. Client roles allow you to create and manage roles and attributes for the network.
For more information, see Configuring Client Roles for AOS-CX.
Device Fingerprinting
Device fingerprinting allows you to classify the end devices connected to an AOS-CX switch. You can find clients’ details such as the type of device, host name, vendor identification, and capability of the device, using device fingerprinting.
In this release, Aruba Central (on-premises) uses device fingerprinting to get only the clients’ hostname.
To enable Device Fingerprinting and DHCPDynamic Host Configuration Protocol. A network protocol that enables a server to automatically assign an IP address to an IP-enabled device from a defined range of numbers configured for a given network. Option 12 on the switch, run the following commands.
(config)# client device-fingerprint profile dfp1
(config)# dhcp option-num 12
To apply Device Fingerprinting profile to the interfaces, for example 1/1/1 to 1/1/3, run the following commands.
(config)# int 1/1/1-1/1/3
(config-if-1/1/1-1/1/3)# client device-fingerprint apply-profile dfp1
Enabling Device Fingerprinting on the AOS-CX switch displays the hostname of the client in the Client Name and Hostname columns on the Clients page.
HTTP Proxy
HTTPHypertext Transfer Protocol. The HTTP is an application protocol to transfer data over the web. The HTTP protocol defines how messages are formatted and transmitted, and the actions that the w servers and browsers should take in response to various commands. proxy enhances security for device management. An IP address can be made a proxy for all HTTP connections. If your network requires a proxy server for Internet access, ensure that you configure the HTTP proxy on the AOS-CX switch to download the image from the cloud server.
For more information, see Configuring HTTP Proxy on AOS-CX.
Managed Mode
When an AOS-CX switch running 10.07 or a later version connects to Aruba Central (on-premises) 2.5.4 or a later version, Aruba Central (on-premises) takes control of modifying the configuration of the AOS-CX switch. A switch cannot be configured using the CLI when the switch is in the Aruba Central (on-premises) Manged mode. Aruba Central (on-premises) becomes the single source of configuration for the switch.
For more information, see Getting Started with AOS-CX Deployments.
Multiple Browser Tab Support and Configuration Drift Warning
Aruba Central (on-premises) allows users to open multiple browser tab sessions of the same Aruba Central (on-premises) instance with a different switch group or device pages simultaneously. For example, you can open the group configuration of a switch in one browser tab and the device-level configuration of a switch in another browser tab.
Aruba Central (on-premises) stores the data from the different browser tabs separately.
However, if you edit the configuration of one AOS-CX switch in the MultiEdit mode in two different browser tab sessions, and try to save the configuration one after the other, the following events occur:
- The configuration that you save first in the editor in any of the two browser tabs is saved on the switch.
- When you try to save the configuration in the editor in the other browser tab, Aruba Central (on-premises) displays a warning that the configuration has been changed outside the current editor.
- If you ignore the warning and continue to save the configuration, Aruba Central (on-premises) overwrites the changes saved earlier with the current changes.
For more information, see Configuring AOS-CX Switches in UI Groups and Editing Configuration Using MultiEdit on AOS-CX.
Source Interface
Aruba Central (on-premises) allows you to configure a single source interface for a service so that all traffic routed through the AOS-CX switch is sent with the same IP address. You can add the source interface only for Aruba Central (on-premises) and User-based Tunneling services in this release for the AOS-CX switch.
For more information see Configuring Source Interface for AOS-CX.
User-Based Tunneling
User-based tunneling uses GREGeneric Routing Encapsulation. GRE is an IP encapsulation protocol that is used to transport packets over a network. to tunnel ingress traffic on a switch interface to a gateway for further processing. User-based tunneling enables a gateway to provide a centralized security policy, using per-user authentication, and access control to ensure consistent access and permissions.
For more information, see Configuring User-Based Tunneling for AOS-CX.
AOS-Switch UI Configuration
The following new features are available for the AOS-Switch UI group and device and configuration.
IP Client Tracker
The IP Client tracker allows you to identify both trusted and untrusted clients that access the system. This feature is supported only on the AOS-Switch 2930F, 2930M, and 3810 switches. This feature is available on AOS-Switch versions 16.10.0008 and later.
For more information, see Configuring IP Client Tracker on AOS-Switches.
Device Identifier for Device Profile
The Device Identifier configuration allows you to configure multiple identifiers for a single device profile. You can create different profiles with predefined rules applicable to a group of devices, directly connected to the switch. This feature is available on AOS-Switch version 16.10.0011 and later. For CDPCisco Discovery Protocol. CDP is a proprietary Data Link Layer protocol developed by Cisco Systems. CDP runs on Cisco devices and enables networking applications to learn about the neighboring devices directly connected to the network., this feature is not supported by the AOS-Switch 2530 and 2920 switches.
For more information, see Configuring Device Profile and Device Identifier on AOS-Switches.
Loop Protection – Disable Timer
The Disable Timer parameter in the Loop Protection tab allows you to access the switch console with non-administrative credentials. This feature allows you to configure a timer to auto-recover ports if the switch detects a loop.
For more information, see Configuring Loop Protection on AOS-Switch Ports.
AI Insights
The following new Switch insights are added in this release:
Availability - Switch
- The PoEPower over Ethernet. PoE is a technology for wired Ethernet LANs to carry electric power required for the device in the data cables. The IEEE 802.3af PoE standard provides up to 15.4 W of power on each port. devices connected to them.
For more information, see AOS-CX Switch Ports with High Power-over-Ethernet Problems
insight provides information on the switches that have not received required power from - The
For more information, see AOS-Switch Ports with High Power-over-Ethernet Problems
insight provides information on the switches that have not received required power from PoE devices connected to them.
Network Structure Page
Under Organization, the Network Structure landing page is added and the existing tabs such as Groups, Sites,and Labels, are added as tiles in this page. You can click a tile to navigate to the respective page.
For more information, see Network Structure.
Group Persona
You can define a persona for devices in a group while creating a group. The persona of a device represents the role that the device plays in a network deployment. Persona and architecture are set at the group level. All devices within a group inherit the same persona from the group settings. You can save the preferred settings to apply the same persona and architecture for subsequent group creations.
For more information, see Groups.
Alerts and Events
The following new alerts are added in this release:
- Switch Reboot Alert—Generates an alert when a switch reboots or crashes. This alert is enabled by default and the alert severity is Critical. This alert is applicable only for AOS-Switch.
For more information, see Switch Alerts.
The following AP client events are added in this release:
- Client Accounting Server Timeout
- Client Authentication Server Timeout
- Radius-COA Failure
- Client Match Success
- Client Match Steer Uncontrolled Moves
- Client Match Steer No Move
For more information, see Supported Client Events for Campus AP and Instant AP Devices.
Aruba Central APIs
This release introduces the following new APIsApplication Programming Interface. Refers to a set of functions, procedures, protocols, and tools that enable users to build application software.:
WLAN Configuration APIs
Following APIs are introduced in the WLANWireless Local Area Network. WLAN is a 802.11 standards-based LAN that the users access through a wireless connection. Configuration category:
/configuration/full_hotspotHotspot refers to a WLAN node that provides Internet connection and virtual private network (VPN) access from a given location. A business traveler, for example, with a laptop equipped for Wi-Fi can look up a local hotspot, contact it, and get connected through its network to reach the Internet./{group_name_or_guid}
/configuration/full_hotspot/{group_name_or_guid}/{mode_name}
/configuration/full_hotspot/{group_name_or_guid}/template
/configuration/full_hotspot/{group_name_or_guid}/{hotspot_name}/{mode_name}
Troubleshooting APIs
category:- /troubleshooting/v1/running-config-backup/serial/{serial}
- /troubleshooting/v1/running-config-backup/serial/{serial}/prefix/{prefix}
- /troubleshooting/v1/running-config-backup/name/{name}
- /troubleshooting/v1/running-config-backup/group_name/{group_name}/prefix/{prefix}
Clients APIs
category:- /monitoring/v2/clients
- /monitoring/v2/clients/{macaddr}
Authentication & Policy APIs
category:- /client_policy
: - /client_policy
: - /client_policy
category:- /client_registration
- /client_registration/{mac_address}
category:- /user_policy
- /user_policy
- /user_policy
Service IPMS APIs
Following API is introduced in the
category:- /ipms-config/v1/node_list/{node_type}/{node_id}/config/address_pool/{pool_name}/ip_range/
- /ipms-config/v1/node_list/{node_type}/{node_id}/config/address_pool/{pool_name}/ip_range/{range_id}/
AI OPs APIs
category:- /aiops/v1/connectivity/global/stage/{stage}/export
/aiops/v1/connectivity/site/{site_id}/stage/{stage}/export
/aiops/v1/connectivity/group/{group}/stage/{stage}/export
category:- /aiops/v2/insights/global/list
/aiops/v2/insights/site/{site_id}/list
/aiops/v2/insights/ap/{ap_serial}/list
/aiops/v2/insights/client/{sta_mac}/list
/aiops/v2/insights/gateway/{gw_serial}/list
/aiops/v2/insights/switch/{sw_serial}/list
category:- /aiops/v2/insights/global/id/{insight_id}/export
/aiops/v2/insights/site/{site_id}/id/{insight_id}/export
/aiops/v2/insights/ap/{ap_serial}/id/{insight_id}/export
/aiops/v2/insights/client/{sta_mac}/id/{insight_id}/export
/aiops/v2/insights/gateway/{gw_serial}/id/{insight_id}/export
/aiops/v2/insights/switch/{sw_serial}/id/{insight_id}/export
For more information, see New APIs.
Enhancements
The following sections provide an overview of the enhancements introduced in Aruba Central in this release.
Configuration
The following UI and template configuration enhancements are introduced in this release.
RRM Quiet IE in SSID
The RRM Quiet IE in the Security > Fast Roaming WLAN SSIDService Set Identifier. SSID is a name given to a WLAN and is used by the client to access a WLAN network. configuration UI page allows you to enable or disable the Radio Resource Management IE profile elements advertised by an AP in the SSID profile.
For more information, see Basic WLAN Security Parameters.
Mesh Support for Multiple Radios
Aruba Central now allows you to configure mesh profiles for multiple radios in the System > Mesh UI page. Although most mesh deployments require only a single mesh cluster profile, you can configure and apply multiple mesh cluster profiles to an individual AP.
For more information, see Configuring Mesh for Multiple Radios.
Fast Roaming with Mesh
The RSSIReceived Signal Strength Indicator. RSSI is a mechanism by which RF energy is measured by the circuitry on a wireless NIC (0-255). The RSSI is not standard across vendors. Each vendor determines its own RSSI scale/values. of the parent is lower than the threshold value.
in the Access Points > Mesh configuration UI page allows you to trigger fast roaming on a mobility mesh point when theFor more information, see Access Points Configuration Parameters.
EST support for Radsec and AP1x
Aruba Central now allows EST to support Radsec , AP1X CACertificate Authority or Certification Authority. Entity in a public key infrastructure system that issues certificates to clients. A certificate signing request received by the CA is converted into a certificate when the CA adds a signature generated with a private key. See digital certificate., and AP1X Client Cert on the AP in the UI page. The Radsec use EST Server allows Radsec to use the certificates enrolled using the EST Profile.
For more information, see Mapping IAP Certificates and Configuring an EST Profile
DHCP Relay Support
The
and in the System > DHCP UI page allows the AP to relay the DHCP requests for , , and DHCP For WLANs.For more information, see Configuring a Centralized DHCP Scope, Configuring Local DHCP Scopes, and Configuring DHCP Server for Assigning IP Addresses to IAP Clients
Campus AP or Remote AP Replacement
- You can now replace a Campus AP or a Remote AP with different models on the AP Summary page.
- After the device replacement, the new AP replaces the old AP's VisualRF floor plan if the old AP was associated with a VisualRF floor plan.
For more information, see Replacing an Access Point.
AOS-CX – SNMP Enable
Aruba Central allows you to enable or disable the SNMPSimple Network Management Protocol. SNMP is a TCP/IP standard protocol for managing devices on IP networks. Devices that typically support SNMP include routers, switches, servers, workstations, printers, modem racks, and more. It is used mostly in network management systems to monitor network-attached devices for conditions that warrant administrative attention. service at the global level on AOS-CX switches. You can also select the VRFVisualRF. VRF is an AirWave Management Platform (AMP) module that provides a real-time, network-wide views of your entire Radio Frequency environment along with floor plan editing capabilities. VRF also includes overlays on client health to help diagnose issues related to clients, floor plan, or a specific location. on which you want to configure SNMP on the switch.
For more information, see Configuring SNMP on AOS-CX.
AOS-CX – Concurrent Authentication
Concurrent authentication is added in the Ports table under the Authentication parameter.
For more information, see Configuring Authentication on AOS-CX.
AOS-CX – Port Filter
On the
> page, in the device view, all access ports are shown by default. The port filter provides options to select All Uplink Ports or All Access Ports. You can also search for a port using the port name.For more information, see Configuring Ports and LAGs on AOS-CX.
AOS-Switch – Multiple DNS Server Support
Aruba Central allows you to configure two static IPv4 addresses for the DNSDomain Name System. A DNS server functions as a phone book for the intranet and Internet users. It converts human-readable computer host names into IP addresses and IP addresses into host names. It stores several records for a domain name such as an address 'A' record, name server (NS), and mail exchanger (MX) records. The Address 'A' record is the most important record that is stored in a DNS server, because it provides the required IP address for a network peripheral or element. servers for AOS-Switches.
For more information, see Configuring a Name Server.
IAP Local Probe Request Threshold and Min RSSI for Auth Request
To improve the performance of the indoor Wi-FiWi-Fi is a technology that allows electronic devices to connect to a WLAN network, mainly using the 2.4 GHz and 5 GHz radio bands. Wi-Fi can apply to products that use any 802.11 standard. clients, this release supports configuring a WLAN SSID with Local Probe Request Threshold and Min RSSI for auth request advanced settings. Based on your selection, the local probe request threshold value and the Min RSSI for auth request changes to the recommended value automatically from the AI insight.
For more information, see Configuring Wireless Network Profiles on IAPs.
IAP Beacon Rate in SSID Profile
The Beacon Rate for 2.4 GHzGigahertz. bandBand refers to a specified range of frequencies of electromagnetic radiation. and 5 GHz band under Advanced Settings in the SSID configuration page is modified. You can only set the maximum transmission rate from the 2.4 GHz and 5 GHz drop-down list.
IAP Add Named VLAN
Aruba Central supports adding multiple VLANVirtual Local Area Network. In computer networking, a single Layer 2 network may be partitioned to create multiple distinct broadcast domains, which are mutually isolated so that packets can only pass between them through one or more routers; such a domain is referred to as a Virtual Local Area Network, Virtual LAN, or VLAN. IDs and VLAN range in the Add Named VLAN window in the SSID configuration page.
Confirmation Message for Deleting a Site
The delete site action now displays a confirmation message. Deleting a site disassociates all devices that are associated with it. The disassociated devices are moved to the unassigned devices list.
For more information, see the Deleting a Site section in the Managing Sites page.
UCC Configuration
In the UCCUnified Communications and Collaboration. UCC is a term used to describe the integration of various communications methods with collaboration tools such as virtual whiteboards, real-time audio and video conferencing, and enhanced call control capabilities. configuration page, the Facetime protocol row and Server column are removed from the table. Additional system default carriers are added to the DNS Pattern list of Wi-Fi Calling protocol.
For more information, see Configuring UCC.
Monitoring
The following monitoring enhancements are introduced in this release.
LLDP Details support on Campus AP
The LLDPLink Layer Discovery Protocol. LLDP is a vendor-neutral link layer protocol in the Internet Protocol suite used by network devices for advertising their identity, capabilities, and neighbors on an IEEE 802 local area network, which is principally a wired Ethernet. Neighbor and LLDP Port details on the AP List page and the LLDP Details on the AP Summary page are now supported on Campus APsCampus APs are used in private networks where APs connect over private links (LAN, WLAN, WAN or MPLS) and terminate directly on controllers. Campus APs are deployed as part of the indoor campus solution in enterprise office buildings, warehouses, hospitals, universities, and so on. as well.
For more information, see Network and Access Points Table.
Location and Contact Details on AP Summary Page
The AP Summary page for an AP with firmware version, ArubaOS 8.9.0.0 or later displays the following:
- Physical location of an AP in the Location field.
- Contact of an AP in the Contact field.
For more information, see Device.
Reboot a Campus Access Point or Remote Access Point
The reboot action support is introduced for Campus Access Points and Remote Access Points in the Details page and List view.
For more information, see Rebooting an AP in the Details Page and Rebooting an AP in the List View
Radio Frequency for Campus Access Points and Remote Access Points
The following features are added for monitoring the Campus APs and Remote APsRemote APs extend corporate network to the users working from home or at temporary work sites. Remote APs are deplyed at branch office sites and are connected to the central network on a WAN link.:
The Frames - 802.11802.11 is an evolving family of specifications for wireless LANs developed by a working group of the Institute of Electrical and Electronics Engineers (IEEE). 802.11 standards use the Ethernet protocol and Carrier Sense Multiple Access with collision avoidance (CSMA/CA) for path sharing. graph in the RFRadio Frequency. RF refers to the electromagnetic wave frequencies within a range of 3 kHz to 300 GHz, including the frequencies used for communications or Radar signals. tab for an AP has Issues & Transmitted Frames filter to view the trend of transmitted frames along with retries, errors and drops in frames per second and Issue % for percentage of retries, errors, and drops.
- The MACMedia Access Control. A MAC address is a unique identifier assigned to network interfaces for communications on a network. Errors along with Total Packets in packets per second. graph has the Physical Errors and
For more information, see Access Point > Overview > RF.
AOS-CX VSF Stack
This release introduces the following enhancements to the
tab:The switch stack faceplate now displays the following configuration and connection errors related to the AOS-CX VSF stack. You can monitor and troubleshoot these errors from the tab:
- Auto-join eligibility error
- VSF link error
- Cabling error
- Incompatible switch firmware error
For more information, see Monitoring AOS-CX Switch Stacks.
Application Visibility
The following improvements are made to the
dashboards:-
The
dashboard now includes Site and Client level support. You can now view the applications traffic flow for both the site and client. - In the tab, the and column are removed from the table. You can use the filter option in the and column to filter any application and category by its name. Use the sort icon to sort the list in an ascending or descending order.
- In the view, the dashboard user interface is enhanced to include a pie chart along with the stacked bars. The new graphs display both the and usage data, along with the clients traffic flow. You can select or deselect the application/ category check box to show or hide the traffic flow data from the pie chart and stacked bar. By hovering the mouse over the pie chart and stacked bar, you can view the size of the data.
For more information, see Application Visibility.
Global Dashboard
The Connection Experience tile in the Summary view of Manage > Overview > WiFi Connectivity tab is changed to a time series graph. You can hover over the graph to see the connection success percentage for a specific time.
For more information, see Wi-Fi Connectivity.
Clients
The List view in the Clients section is enhanced with the following features:
- The filter criterion for the MAC Address column supports all delimiters when searching for a MAC address. You can search for a MAC address with any delimiter, Aruba Central automatically converts it to a semicolon and displays the corresponding results.
- The
download icon is moved next to the
ellipsis icon in the Clients table for quick and easy access. The download icon exports the data in the table to a CSVComma-Separated Values. A file format that stores tabular data in the plain text format separated by commas. file.
- In the List view, you can hover over the row for a wireless client and select DISCONNECT FROM AP to disconnect the client from an AP.
For more details, see All Clients and Disconnecting a Wireless Client from an AP.
Download Client Live Events
The clients Live Events page allows you to download the list of live events to a CSV file for offline analysis.
For more information, see Client Live Events.
Download AP Live Events
The AP Live Events page allows you to download the list of live events to a CSV file for offline analysis. For more information, see AP Live Events.
Health Bar on the Site Health Dashboard
The Health Bar in the
tab displays a short description for the potential issues at the site and the devices connected.For more information, see Site Health Dashboard and The Health Bar.
Timezone on the Site Health Dashboard
The Site Health dashboard now displays the timezone and local time of the site. For example, IST-11:25 AMAir Monitor. AM is a mode of operation supported on wireless APs. When an AP operates in the Air Monitor mode, it enhances the wireless networks by collecting statistics, monitoring traffic, detecting intrusions, enforcing security policies, balancing wireless traffic load, self-healing coverage gaps, and more. However, clients cannot connect to APs operating in the AM mode.. For more information, see Site Health Dashboard.
The clients graph in the AP Performance tab now displays the number of clients connected per radio. For more information, see Access Point > Overview > Performance.
Wired Clients in Data Path -
The AP Summary page displays the number of ports that include USBUniversal Serial Bus. USB is a connection standard that offers a common interface for communication between the external devices and a computer. USB is the most common port used in the client devices. ports available in the AP and the number of wired clients connected to the AP in the data path.
For more information, see Data Path.
Topology Page
In the Topology page, the Show Device Labels is now renamed to Show Device Names.
For more information, see Monitoring Sites in the Topology Tab.
UCC Monitoring
The following improvements are made to the UCC monitoring dashboard:
- The Summary bar is removed from the UCC > List page and added as a Call Quality column in the Calls table. You can filter the data by Good, Fair, Poor, or Unkonwn calls. The
and
icons are added to the CDRCall Detail Record. A CDR contains the details of a telephone or VoIP call, such as the origin and destination addresses of the call, the start time and end time of the call, any toll charges that were added through the network or charges for operator services, and so on. column to indicate wireless and wired connections.
- In the UCC > Summary page, the default option to view the graph is changed to Protocol. The scatter plot graph is removed for the Health option. The per AP and per Client graphs are also removed from this page.
For more information, see Monitoring UCC in List View and Monitoring UCC in Summary View.
Floor Plan
feature:- The floor plan user interface for a site has been enhanced and now includes a
add icon and can also search for an AP or floor names using the
search icon. The list view displays all the floors in a table.
view and view. The summary view in the dashboard now features the tile that displays all the available floors in a tile view for a selected site. You can add a new floor using the - The view mode of a floor is also enhanced to provide a better user experience. For a selected floor, you can now view the floor details in the
icon. To view any device details in the window, click any device in the floor plan. You can also view the settings applied to the floor plan by clicking the
icon.
window by clicking the - The new dashboard for the site, allows you to delete or edit a floor plan directly from the summary view and the list view.
For more information, see About Floorplans.
Controller Summary
The Location and Contact details are added to the Summary tab for a controller.
For more information, see Controller > Overview > Summary.
Firmware Upgrade and Compliance
dashboard:-
Under the
radio, the drop-down menu includes the option that allows you to schedule compliance and upgrade based on the local site time. - The , , and option includes a drop-down option that allows you to select a Primary or Secondary partition to install the firmware.
The
table includes a column that displays the group to which the devices are associated. This information is available only in the global context. - At the device level when you hover over the
- version number and compliance configured level for a set compliance
- date, time (UTCCoordinated Universal Time. UTC is the primary time standard by which the world regulates clocks and time.), and firmware version number
- compliance configured level for a scheduled compliance
column, the following information is displayed:
For more information, see Upgrading Device Firmware.
Reports
The following enhancements are added to reports.
Uptime for an Offline IAP
In the Network report, the - (hyphen) symbol in the Uptime column of APs table indicates that the corresponding IAP is in offline status.
For more information, see Report Categories.
Wired Client Support in Client and Network Reports
- The explicit details for the wired clients are available in the Client Inventory, Client Usage, Client Session, and Network reports.
- In the Client Inventory report, the Client Count by Connection Type table displays the client count by wireless and wired connection type.
In the Client Usage report, you can filter the data in the Top Ten Clients by Usage widget by All, Connection Type (wireless, wired, or remote) or SSIDs. The inbound and outbound clients data usage metrics is displayed in the Client Usage widget by Connection Type (wireless, wired, or remote) and client count data metrics is displayed in the Client Count widget by Connection Type (wireless, wired, or remote).
In the Network report, you can filter the data in the Top Ten Clients by Usage widget by All, Connection Type (wireless, wired, or remote) or SSIDs. The Wired Clients and Peak & Average Wired Data Usage widgets are also added. The client count is displayed on the time series graph in the Wired Clients widget. The inbound and outbound peak or average data usage metrics is displayed in the Peak & Average Wired Data Usage widget.
- In the Client Session report, the Session Data By Role and Clients By Role widgets display the details by role, connection type (wireless or wired) and SSIDs. You can filter the data in the Top Ten Clients by Usage widget by All, Connection Type (wireless or wired) or SSIDs.
RF Health Report
In the RF Health report, the Optional Widgets section is introduced to include the RF Details and IAP Uplink Usage details in the CSV format. The IAP Uplink Usage information is available only for Instant APs with Advanced license.
For more information, see Report Categories and Report Configuration Options.
Alerts and Events
The following alert and event enhancements are introduced in this release:
Suppress Alerts
In the Site context, while suppressing alert notifications, you can select Override or Append to either override or append the configured email addresses to receive notifications when an individual or site level alter alert is generated. You can also override or append the configured default recipient email list to receive alert notifications.
For more information, see Suppressing Alert Notifications in the Site Dashboard and Adding Default Recipients.
Filter Events
The Events table columns enables filtration and search ability at all levels. It also allows free text search to enhance the search capability. You can also copy and paste text on the column headers to improve the search mechanism.
For more information, see Viewing Events List View.
Client Event Filter
Aruba Central allows you to troubleshoot issues related to a wired or wireless client connected to IAPs. The Events tab in the client context provides a detailed drill-down capability to filter events further to identity a specific issue and perform troubleshooting in both List and Summary view. It provides an aggregate view of events in different categories to provide a deep insight to the client's health.
For more information, see Client Events.
Troubleshooting Tools
In the Network Operations app, use the filter to select a group, label, site, or a device and then, select Analyze > Tools to use different troubleshooting tools. The Tools menu option enables users to troubleshoot AP, gateway, and switch issues in the network through various tests available in the Network Check, Device Check, and Commands tabs. The following troubleshooting enhancements are introduced in this release.
VLAN-based Ping Test
Under Analyze > Tools > Network Check, you can now perform ping test based on VLAN IDs on IAPs running on firmware version AOS 10.3 and later, to troubleshoot network issues. The SSID drop-down is added to enable users to troubleshoot client SSIDs.
For more information, see Troubleshooting AP Connectivity Issues.
Status Indicator in Logs Collection
In the
> > tab, the Status column now displays a status bar when you upload logs. The status bar displays the Scheduled, In Progress, Complete, or Failed statuses as a percentage value, as the logs are uploaded. This helps customers and internal users to understand the status of the log collection.Live Events – Wired Client Packet Capture
Aruba Central now allows read-write and admin users to launch targeted packet capture on a wired client connected to a gateway or switch. Packet capture can be done at a site level or for a selected client.
API Gateway
The
tab is now enhanced to include to include a status bar that displays the current usage of API calls assigned for a day along with the reset time in local time zone.For more information, see Viewing Usage Statistics.
System Administration
SCP Protocol for Data Backup
The SCPSecure Copy Protocol. SCP is a network protocol that supports file transfers between hosts on a network. option is added as a Protocol Type in the System Management > Backup and Restore tab to allow users to take data backup based on the available server.
For more information, see Backing up and Restoring Aruba Central System Data.
Aruba Central APIs
Following are the API changes and enhancements:
Clients APIs
The following enhancements are made in the APIs in the
category:- /monitoring/v1/clients/wireless
/monitoring/v1/clients/wired
Topology APIs
category:- /{site_id}
/devices/{device_serial}
For more information, see Modified API.
